Button backlight times out while still using the remote
Re: Button backlight times out while still using the remote
1 year 4 months ago
#4327
It's all good. Your suggestion gave me what I needed in order to look at it differently and approach the problem from another angle.
Good luck in Orlando! I'd love to go but it's the week of my 20th anniversary. Somehow I'm thinking the wife wouldn't be amused lol
bitzerjd's Avatar
1 year 4 months ago
#4332
What is the variable for the actual Smartremote name?  I want the WakeupMyRemote command to only execute on the remote where the button is pushed.  I'm assuming it's something like WakeupMyRemote|{{Variable}}.
1 year 4 months ago
#4333
WakeupMyRemote|{{clientname}} should probably work.
bitzerjd's Avatar
1 year 4 months ago - 1 year 4 months ago
#4334
I don't use "Clientname", and it's not defined as a system variable. I don't use the normal Allonis activate macros which usually define that variable. I will dig a bit more into the stock macros and see how Allonis defines the variable.
Update - Works fine...  clientname returns the right value.  I guess it's a built in system function vs a "Server Variable".
Last edit: 1 year 4 months ago by bitzerjd.
1 year 4 months ago
#4335
I don't think that SetActiveSource defines {{clientname}}. I believe it defines other variables that use {{clientname}} within them. I'm pretty sure {{clientname}} is defined by whatever Client Name is assigned to the remote in the Server Connection Options on the remote itself. By default these are randomized (remote3, remote8, etc) though you might have changed this when you initially set up the remote.
bitzerjd's Avatar
1 year 4 months ago
#4336
What was confusing was that clientname didn't show up in the list of Server Variables.  The remote names also didn't appear as a value.
All is good now...when my wife is using the tivo guide to look for something to watch, the remote stays on the entire time.
Happy Wife = Happy Life!
Thanks for the help!!!
Time to create page: 0.294 seconds
