2 years 1 month ago
#3147
Same message trying to put the remote to sleep from the server...
29/08/2024 23:50:44.50 · DEBUG · Server.doCommand - AV|42~SendKey~SLEEP command
29/08/2024 23:50:44.50 · DEBUG · AndroidTV.doCommand - Cmd=[42~SendKey~SLEEP command] Client=[dashboard-fx-ghg8]
29/08/2024 23:50:44.50 · DEBUG · AndroidTV.doCommand - Reconnect to 192.168.2.47:55055
29/08/2024 23:50:44.50 · ERROR · AndroidTV.doCommand - Error in MoveNext - Object reference not set to an instance of an object.
2 years 1 month ago
#3149
I think I had the same thing when I was first starting to setup the SmartRemote. I ended up uninstalling the smartremote .apk from the device and reinstalling it and then it worked.
2 years 1 month ago
#3150
Hi Bitzer, Your smartremote is device id 47, not 42. try that
2 years 1 month ago
#3151
I deleted the two devices in AndroidTV and deleted the driver. I reinstalled the driver and discovered the two remotes... Same issue.
David - I have two remotes the were 42 and 43. I did a couple of rediscovers and tried the new ID.
The new IDs are 47 and 50. Both generate the same error as stated above.
2 years 1 month ago
#3152
I was able to get the server to send
AV|50~Restart
and
AV|47~Restart
and it worked...
This command will not...
AV|47~SendKey~SLEEP
or
AV|50~SendKey~SLEEP
2 years 1 month ago
#3153
Just checking...did you upgrade to the latest apk?
