Remote periodically locking up
bitzerjd's Avatar
Re: Remote periodically locking up
1 year 11 months ago
#3595
I'm also getting...
01/11/2024 09:31:36.31 · DEBUG · AndroidTV. - The device {192.168.2.47:55055} has changed
01/11/2024 09:31:37.31 · DEBUG · AndroidTV. - The device {192.168.2.166:55055} has changed
However I do not get the disconnected message. This happens randomly, sometimes during the middle of the night and sometimes during the day.
What does this error message mean? Is it something to worry about?
#3596
David was right my freezes were due to a wifi issue. For whatever reason whatever remote is in the sunroom is bouncing back and forth between connecting to two different access points in the house.
I don't quite understand what happened to cause this. The one is much further away and has a much weaker signal. It also doesn't happen with any other device in the room. This has never been an issue until the last 2 weeks or so.
Even still, at least the problem has been identified. For the moment I have the problematic access point disabled until I can come up with a more robust solution and the connection to the remote is now completely stable.
#3597
Good to hear. Thanx for the update.
WiFi can be a bugger to get right.
Depending on your WiFi firmware, you might be able to lock a device to a particular Access Point to keep it from roaming.  Of course that tends to lock that remote to a physical area, but it might always be in that room anyway.
#3598
The Device Change event is not an error. Simply a message stating that the device has changed state. Usually it is sleeping / awake but I guess in your case it was switching access points upon a sleep / wake event. Device change events are normal and by themselves do not indicate any error condition.
