Hard Buttons
Re: Hard Buttons
#951
Not able to open any html.  Flashes and nothing.
JGrana01's Avatar
Re: Hard Buttons
#954
Hmm, that's the real problem...Maybe restart myServer and myDesigner.
Possibly out of sync?
Re: Hard Buttons
#956
That's a no go.
RoyN's Avatar
Re: Hard Buttons
#958
It seems like you are having problems with your myDesigner... Did it work at any point? Did you do the network share test, etc? (There are some youtube videos about this).
in summary, open windows explorer and navigate to \\[myServerIP]\myServer if it asks for a password and user use allonis / allonis and click "remember password" or equivalent. Then myDesigner should be able to see the files. (remember to replace [myServerIP] with the actual myServer IP... something like 192.168.xxxx or 10.xxxxx or similar)
JGrana01's Avatar
Re: Hard Buttons
#960
One more idea. Can you see the files with Windows Explorer? myServer runs an SMB share.
You can try to see if it is some kind of SMB issue. myDesigner mounts this share and then takes the files from myServer.
I have setup a permanent share on my Windows 11 box.
If you haven't done this yet, try to Map a Network Drive using:
Drive: (whatever Windows decides)
Folder: \\your_myServer_IP_address\myServer
Windows might ask for login/password. User is allonis Password is allonis
See if you can then navigate to the wwwroot/smartremote directory. All the html files for it are there.
You can open any of them with Notepad and see the details.
Dont make any changes to this file!!! Just look and see
Re: Hard Buttons
#962
If i uninstall myDesigner and reinstall it what will happen to my projects?
Time to create page: 0.254 seconds
