This works for volume, but only works for power if you assume the intent is to power on or power off everything in the room.We want to try to reduce the number of macros being created but wasn't expecting someone to reflash a new server so soon. Instead of VolumeUp, VolumeDown, PowerOn, PowerOff it's better to have just one Volume and Power macro and pass in the options as needed.
I haven't done any testing on this but could the <p1> be used in a if command follow the example I usedThis works for volume, but only works for power if you assume the intent is to power on or power off everything in the room.
I have the power on macro for the room set to turn on the TV and the Receiver only. Different source devices get their power on command if/when activated. Power off turns off everything.
I know that I can still make it work if there is a single macro, but I will need to add conditional statements. It is cleaner to use two macros.
