Does it look like this?There is a display issue in Parallels Windows VM on a Mac. The icons at the top are cut off. Making the software unusable. I am unable to upload a picture, not sure if is due to being a newer user.
Yes, the resolution change is the fix.Thanks, that did end up working. When using Parallels you have to do it from the Parallels menu, not the Windows menu.
I'd still consider the issue as 'open'. Low resolution mode looks bad and should not be required.
