MyDesigner and SMB issues...
#1471
I believe I have a SMB Windows 11 issue that I just cannot solve that causes MyDesigner to hang.
MyDesigner succesfully connects to the server and correctly lists all my projects in the left hand pane which I can load and edit.
However... if I ever go to click the 'three dots' icon to browse (for example) images, MyDesigner hangs.
Connected with this - in Windows 11 - I can (and have) mapped a drive to '[IP of server]/myServer' and through that mapped drive I can navigate the files and folders of myServer.
What I cannot do is navigate manually to the share via explorer (ie typing in '\\[IP ADDRESS]\myServer' - nothing happens.
I have used cmd to run 'control userpasswords2' and removed all relevant credentials from Windows passwords and started over, but still the same behaviour happens.
Am currently stuck with a regularly hanging MyDesiger6 and cannot easily import images (though if I type the path and file name in manually it loads....)
Re: MyDesigner and SMB issues...
#1473
I run myServer in a virtual machine on a QNAP.  After installing and configuring Samba, I also installed WSDD (Web Service Discovery Daemon) which makes a Samba host discoverable by Windows clients.  (sudo apt install wsdd)
Assuming you are running on Allonis supplied hardware, I don't know if installing WSDD is an option.  But I suspect it would solve your problem.
#1474
As an experiment right-click on Windows 11 start button. Choose run.  In the Open text box enter \\[IP ADDRESS]\myServer and click ok. Are you prompted for credentials? If yes then enter allonis / allonis and make sure to click on remember. If no then does that open the share and you can browse files?
#1476
Not prompted for anything.  Nothing happens.
Trying to manually navigate there in explorer sometimes (after a lengthy delay) brings up a credentials box.  Log in as other user > allonis | allonis.  And Nil.
Yet....
Mapping a drive to the share works perfectly.  Very odd.
#1477
sudo apt install wsdd did not appear to work.
Manually installing wsdd did work and caused the server to auto appear in Windows 11 network discovery.
But I am still wrestling with trying to get in....
#1480
I've given up for now and in the settings part of myDesigner where it asks for the share path I put the mapped drive letter to the share. In my case this is m:
This seems to work for loading/saving projects and scenes and browsing the image folders.
