Does myServer know when an App is launched?
Re: Does myServer know when an App is launched?
2 years 2 months ago
#3070
You can have automations run every second if you want. I have my lumagen status run every 30 seconds. My automation fires when {{current_uptimesecs}} > {{my_lumagen_status_check_time}}. It then calls a macro which does the status call and does Math|Add~my_lumagen_status_check_time~ {{current_uptimesecs}}~30. That will cause the automation to fire 30 seconds from now.
#3071
Ah that's clever - I was just looking at the scheduling options. I might get rid of my Linux cron job now to keep it all inside myServer. Thanks.
2 years 1 month ago
#3128
The Android driver does know what app is running. It was just not being exposed as a server variable. With the current driver you will see two new variables {{av_<id>_active_app}} and {{av_<id>_active_launcher}}
You can trigger automations to run every second if needed. Here's every 30 seconds
WHEN: {{current_second}} changes value
Switch|{{current_second}}##0##DO SOMETHING##30##DOSOMETHING
Or using if statements
Macro|
If|IsEQ##{{current_second}}##0##DO SOMETHING!
If|IsEQ##{{current_second}}##30##DO SOMETHING!
Time to create page: 0.248 seconds
