- Thank you received: 12
NVIDIA Shield Pro 2019
- cjisble
2 years 5 months ago #580
by cjisble
NVIDIA Shield Pro 2019 was created by cjisble
The documentation for the Android TV driver:
allonis.com/support/documentation?view=category&id=144
explains how to setup the Shield.
However, this part:Restart myServerIn a few seconds, you should see an acceptance request on the Shield screen. Accept to allow the ADB communications from myServer (saved).Note: this maybe broken in Shield 9.0 and 9.1...researching
Is broken.
Running 'adb devices' confirms that the Shield is attached, but unauthorized.
I thought that having this in a forum post rather than a note in the documentation would make it easier to be notified when it is fixed.
Is broken.
2 years 5 months ago #582
Replied by David Li on topic NVIDIA Shield Pro 2019
Latest myServer 64 bit image (what you have) should have the Nvidia shield prior issue resolved. We have tested it with latest Shield OS. I updated the docs to remove that warning.The documentation for the Android TV driver: allonis.com/support/documentation?view=category&id=144 explains how to setup the Shield.
Is broken.
- cjisble
2 years 5 months ago #585
by cjisble
Replied by cjisble on topic NVIDIA Shield Pro 2019
I am running 6.7.3220.2252, which is the latest available. Even after rebooting, I am not getting the prompt to authorize.
2 years 5 months ago #589
Did you send the authentication token from the AndroidTV driver?
The popup sometimes doesn't show up immediately. Can take a few minutes.
did you enable Developer mode and did you within Developer mode enable ADB communications?I am running 6.7.3220.2252, which is the latest available. Even after rebooting, I am not getting the prompt to authorize.
- cjisble
2 years 5 months ago #590
by cjisble
Just reread the documentation. Still missed this step. How do I do this?
No. I missed this step.Did you send the authentication token from the AndroidTV driver?
2 years 5 months ago #598
Actually, the ADB in myServer install will connect automatically once added. Try using Discovery.
Time to create page: 0.170 seconds
