Setup of Panasonic UB-820
Re: Setup of Panasonic UB-820
#1189
I'm such a clown some days. Scene works fine. Commands are sent, uhd player responds great.
#1191
I deleted and re-added my player, using the latest version of the driver.
Source was created automatically, as expected.
kirky27's Avatar
#1194
Where/how do you create the source and the macro?
#1195
Something is still not quite right.
On the server, in the GenericIR Device configuration, I sent the command to open and close the tray.  It works correctly.
After configuring the BluRayIR device, it appears on my Smart Remote.  However, when I hit the Open/Close button, nothing happens.
When I build the command to Add Player, the IR Device Model has the player in the drop down list, but the IR Device ID has nothing.  I tried manually entering either SR1 (the name I assigned to the Smart Remote as a Generic IR device) or Control|1 (the family and ID).  Neither one worked.
I also tried deleting and re-adding both the GenericIR device and the BluRayIR device, but the smart remote does not appear in the IR Device Model list.
Just to clarify:  During the Smart Remote Setup, on the Server Connection Options, I set the Client Name to SR1.  This is also the client name that shows up on the MyServer dashboard.
Last edit: 2 years 7 months ago by cjisble. Reason: Add note about changing the default client name during setup.
#1196
They are created automatically when you configure the BluRayIR device.  You must be using the driver that was just released today.  After deleting and re-adding the device, the source and macro appeared on the server.
The following user(s) said Thank You: kirky27
#1273
I checked the log file.  The actual command being sent is:  AV|~Remote~Open/Close
Note that the ID is missing.
