Caseta driver
retate's Avatar Topic Author
Re: Caseta driver
#1067
I was having the same issue where the Caseta Driver didn't seem to work at all but the Lutron driver did.
I noticed my bridge in the Caseta Driver was showing up with an ID of -1. I changed that to +1, which agreed with the ID in the caseta1.txt file, and reran the import command. This populated all of my devices. I will need to go through and update the names and rooms, but everything seems to work.
My Caseta Smart Bridge Pro properties also shows an ID of -1. It has been that way for multiple instances of removing and adding the Smart Bridge Pro entry. I have not tried changing that to +1 in my experimentation. I directly placed my integration file into the data directory with SCP as I was not originally aware of the import command. If the file needs to be brought in via the import command the instructions should be updated to say that.
I have forwarded my integration file to Dave, per request.
Re: Caseta driver
#1080
I just updated the Caseta driver after successfully importing the three sample files I received today. You will now find pico remotes, keypads and sensors being imported.
The driver exposes Press and Release commands for the Picos.
Re: Caseta driver
#1088
Dave, I assume there is something simple I am missing, but I still don't see any attached devices after trying an Import multiple different ways. Assuming the following
- myServer and the Caseta driver updated as of this evening.
- "caseta1.txt" in "home/allonis/myServer/data" directory (file I sent you earlier today)
- "caseta1.txt" file has an ID of 1 for the Smart Bridge Pro
- myServer Lighting Family entry for the Smart Bridge Pro with the Controller ID changed from -1 to 1.
- Log file shows Caseta entries for various unknown devices (numbers correlate with what is connected to my Smart Bridge Pro).
Is the following a valid import command?
 "Caseta|Import~1~/home/allonis/myServer/data/caseta1.txt" with the following log messages
20/02/2024 22:47:20.47 · DEBUG · Server.doCommand - Caseta|Import~1~/home/allonis/myServer/data/caseta1.txt from dashboard-fx-ergv
20/02/2024 22:47:20.47 · INFO · Caseta.doCommand - Cmd=[Import~1~/home/allonis/myServer/data/caseta1.txt] Client=[dashboard-fx-ergv]
I have logging set to Verbose in the Caseta driver, but I do not find these log messages helpful. Did the command succeed or fail? Was the file imported or not?
Last edit: 2 years 7 months ago by retate. Reason: Formatting
RxJoshRx's Avatar
Re: Caseta driver
#1089
I just went into the Lutron Caseta driver and added my controller first- clicked the pencil and update the CotrolerID from -1 to 1 and added the IP address of the hub.
Then I went in and imported the file with the command Caseta|Import~10~caseta1.txt and everything then populated. I tried exactly what you did at first- I used the entrire pathway to the file like it says to do and nothing happened- I then just tried with caseta1.txt and my lights auto populated in the list- doesnt have any specific names like others have mentioned and mine are all listed as Main Lights-
I had already got mine set up through the plain Lutron driver and have already named them in there- probably will delete these since I dont plan on using the pico remotes for any specific programming- just have them on the walls to act as my 3 way switch.
***Edit- I my did not auto populate any of the pico remotes I gave paired to the lights- but wouldnt think they would since the pro hub doesnt add them automatically like the regular smart hub did for me in the past.
Last edit: 2 years 7 months ago by RxJoshRx.
The following user(s) said Thank You: retate
Re: Caseta driver
#1090
Thank you!!! I had tried many variations, but I hadn't tried giving only the file name. My 72 devices all populated. I also will disable most of my Pico's. I need to adjust some names, but it was good to see that the room names I quickly checked are correct.
Last edit: 2 years 7 months ago by retate. Reason: Fix spelling error
RxJoshRx's Avatar
Re: Caseta driver
#1096
Not a problem and glad I could help out. Im not having any issues getting everything discovered but lost when it comes to macros and actually getting it setup to work....
