Language
Sat32's Avatar Topic Author
Language
#1114
Hello,
I've been using using notepad++ to work on macro's and stuff.
Is there any chance we could get "User Defined Language template"
for myserver? right now it's not really needed. But as things start to get more
refined and complex with our configurations it might a great help.
What does everyone else think, for or against?
Re: Language
#1117
I'd vote for changing the embedded scripting language to something standard like Python, C# or JavaScript but I know that isn't going to happen.
Re: Language
#1122
Server macros have to be written using native myServer command syntax. While there are hundreds of server commands in day to day use you really only have to master a handful of them.
You are certainly free to write external scripts in other languages of your choice to do things. The server supports a Run|<something> command just for that.
Re: Language
#1128
I was being facetious but that's really useful to know, thanks. And you can call myServer commands from an 'outside' script by GETting a URL. So some event in myServer could trigger something complex in an external script which in turn calls myServer stuff (as long as you're careful not to get into a loop). Nifty.
Re: Language
#1134
"With great power comes great responsibility" ...Peter Parker
Re: Language
#1137
npp-user-manual.org/docs/programing-languages/
It's just an editor but if the language was defined it highlights comment tags and supports nesting commands and point out errors in your syntax.
The C or C++ language highlights the commit tags in green making it a little easier to read.
As I said right now might not be needed but as macro start to include conditional commands setting variables it might be helpful.
What I mean is copying your macro into the notepad++ editor then pasting it back into the
myserver editor after your done editing
