Linux Terminal option
randyf's Avatar Topic Author
#1540
If I'm running the dashboard URL from a Windows machine and go to Utilities > Linux Terminal, I'm seeing a "refused to connect" error.  It looks like its trying to open port 9001 on the server.  Is this a config issue with my router or some other problem?
I can open a terminal window while on the Raspberry PI machine using the terminal icon in the lower left corner.
Re: Linux Terminal option
#1543
You will need to either be on the latest master image (already posted) or follow these instructions to add it to your existing image
allonis.com/support/documentation?view=category&id=426
#1545
I missed these new features. Were they announced somewhere?
PhoenixF15E's Avatar
#1546
I have the same issue--"Refused to Connect."  I couldn't find anything useful in Wireshark to show where it went off the rails.
I moved the Myserver pi to a different rack so it will take me a bit to see if the required packages are loaded.
#1547
Did you follow the instructions in the link David provided? I had couldn't connect, followed the instructions and it now works.
If you are not using the latest master image then: In a terminal window: // ShellInABox sudo apt install openssl shellinabox sudo nano /etc/default/shellinabox Change SHELLINABOX_ARGS="--no-beep --disable-ssl" sudo systemctl restart shellinabox
#1549
Yep, following these instructions made this work for me as well.
Thanks David.
