AV device ID update
retate's Avatar Topic Author
AV device ID update
2 years 5 months ago
#2241
I have found that when I remove an AV AVR device that was assigned to a room, and then discover the device and assign it to the same room the device ID changes. However, the variables for the room such as bedroom1_avr_id and bedroom1_avamp_id will still have the ID associated with the device that was removed so commands will be sent to the wrong device ID. I have been able to use the Server Variables tab and change the ID to the new value. Is the behavior I am experiencing the expected behavior? If the behavior is expected is the updating the system server variables the only way to deal with this issue?
Re: AV device ID update
#2243
I consider this a bug.  I had this happen to multiple devices before I realized what was happening.
My solution was to remove all the devices and remove all the server variables that were device specific.  Adding everything back again got things in sync.
#2245
You shouldn't be using the device specific variables in your macros or the remote. You should be using the variables like {{active_avr_{{clientname}}}} to get the device id of the active AVR. So in your macro your commands would look like this:
AV|{{active_avr_{{clientname}}}}~Power~On
Then you can switch the AVR device id and it doesn't break everything.
#2246
Hmmm, after my initial comment I went and I tried changing the ID of one of my devices just to make sure what I said was correct. So I changed the avr to a new ID and as soon as I selected the room it changed both the {{active_avr_{{clientname}}}} and the {{theater_avr_id}} value. So maybe there is some sort of issue here. I'm not sure why yours didn't update like mine.
Edit: Is it possible you just need to re-select the room and the ID will update?
Last edit: 2 years 5 months ago by bowlingbeeg.
#2247
bowlingbeeg post=2246 userid=652
The behavior I was seeing only involved myServer generated code/macros. I found this looking at the log file and realizing that the reason a device was not turning on was because the device ID was from a previous definition.
By "re-select the room" do you mean editing the AVR device room definition or did you have something else in mind?
I have also noted with device IDs that in some cases when a device has been deleted, the ID will be reused when a device is added. In other cases, the device ID appears to never be reused.
#2248
By re-select I mean go and click the room again on the remote so that it hopefully will update the id.
Time to create page: 0.262 seconds
