myDesigner display issue in Parallels
billd's Avatar Topic Author
There is a display issue in Parallels Windows VM on a Mac. The icons at the top are cut off. Making the software unusable. I am unable to upload a picture, not sure if is due to being a newer user.
Re: myDesigner display issue in Parallels
Does it look like this?
If so it might be you've got a high DPI screen and have scaling set. On my Surface Book it looks like this with display scaling set to 200%. If I change it to 100% it looks correct.
Thanks, that did end up working. When using Parallels you have to do it from the Parallels menu, not the Windows menu.
I'd still consider the issue as 'open'. Low resolution mode looks bad and should not be required.
Yes, the resolution change is the fix.
We are migrating myDesigner to working via web (no more Windows required).  That's a lot of work and no promises on when it will be done.
Since many of the current issues have all been Windows related...can't wait...
The following user(s) said Thank You: Fattykidd, billd
RoyN's Avatar
Hi billd, is your mac Intel or Apple Silicon (Mx series)?
While on the topic of myDesigner running on Windows....what we learned today:
Microsoft has stopped shipping VC++ redistributable packages with Windows 11. It has now been added installing the VC++ as part of the designer install.
Hopefully that and file sharing properties will address folks that have had challenges getting myDesigner installed and connected to myServer.
