Is it possible to send any command to the AVR?
#1265
Looking at the drop down of the available commands for the Denon AVR and there aren't very many commands listed.  Is it possible to send commands that aren't in that drop down list?  Like if I wanted to switch the monitor out or toggle the 12v trigger?  I know those commands are available to send over an IP command but I'm not sure how to send them through the driver.
Re: Is it possible to send any command to the AVR?
#1983
Do you have a list of commands that you know the AVR supports that are not currently in the driver?  If so, we can see how to implement those.
#2001
Yes you can send any command you like. All the drivers with text protocols have a hidden "Test" command for doing just that.
AV|<id>~Test~<any appropriate device command>
#2013
The Denon AVRs have tons of direct commands so having a way to arbitrarily send any of them would be nice. But common ones(or at least ones I use) would be:
  1. Up - MNCUP
  2. Down - MNCDN
  3. Left - MNCLT
  4. Right - MNCRT
  5. Enter - MNENT
  6. Back - MNRTN
  7. Info - MNINF
  8. Menu on/off - MNMEN ON/OFF
  9. Monitor Out 1 - VSMONI1
  10. Monitor Out 2 - VSMONI2
  11. Trigger 1 on/off - TR1 ON/OFF
  12. Trigger 2 on/off - TR2 ON/OFF
  13. Audio Delay Up/Down/## - PSDELAY UP/DOWN/##
#2014
Cool, just tried the Test command and I was able to send arbitrary commands to the Denon. You might want to consider adding it to the list of commands available in the driver command testing dropdown so others can find it.
2 years 3 months ago
#2869
Relative newbie here - have setup my own Pi4 with the master image of myserver6 from the site. I've made good progress setting up a tablet to replicate my old iRule setup over the last month, following all the available instructions/ videos....
Was delighted to be able to make the volume slider work for my Denon receiver, using the volume variable the other day.
As per the above posts, there are many available commands for Denon receivers. I'm yet to try adding some using the hidden test command, but will do so.
Is there any way for the user to add additional variables to a driver?
My old iRule setup had feedbacks on pretty much every function, running queries on the swiping/ entering each page, and I'm keen to replicate these - particularly the surround mode (MS?), but ultimately the levels of all channels...
The iRule xml file pulled from my setup on a jailbroken iPad lists all the following - is it of value to build these into the Denon driver - in particular the queries - if there is no way the user can easily add them?
Many thanks for everything so far!!
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Device id="8100394068" name="Denon AVC-X4700H RS232/TCP" fixed="0" vendor="Denon" model="AVC-X4700H" metadata="15070040" useForVolumeControl="0">
<CodesType name="Global Cache Codes"> </CodesType>
<CodesType name="Hex Codes"> </CodesType>
<CodesType name="Network Codes">
<Code name="POWER STATUS QUERY" repetition="1">PW?\x0D</Code>
<Code name="POWER STANDBY" repetition="1">PWSTANDBY\x0D</Code>
<Code name="POWER ON" repetition="1">PWON\x0D</Code>
<Code name="POWER MAIN ZONE QUERY" repetition="1">ZM?\x0D</Code>
<Code name="POWER MAIN ZONE OFF" repetition="1">ZMOFF\x0D</Code>
<Code name="POWER MAIN ZONE ON" repetition="1">ZMON\x0D</Code>
<Code name="POWER MAIN ZONE STBY QUERY" repetition="1">STBY?\x0D</Code>
<Code name="POWER MAIN ZONE STANDBY 1HR" repetition="1">STBY1H\x0D</Code>
<Code name="POWER MAIN ZONE STANDBY 2HR" repetition="1">STBY2H\x0D</Code>
<Code name="POWER MAIN ZONE STANDBY 4HR" repetition="1">STBY4H\x0D</Code>
<Code name="POWER MAIN ZONE STANDBY OFF" repetition="1">STBYOFF\x0D</Code>
<Code name="POWER MAIN ZONE ECO QUERY" repetition="1">ECO?\x0D</Code>
<Code name="POWER MAIN ZONE ECO ON" repetition="1">ECOON\x0D</Code>
<Code name="POWER MAIN ZONE ECO OFF" repetition="1">ECOOFF\x0D</Code>
<Code name="POWER MAIN ZONE SLEEP QUERY" repetition="1">SLP?\x0D</Code>
<Code name="POWER MAIN ZONE SLEEP 120" repetition="1">SLP120\x0D</Code>
<Code name="POWER MAIN ZONE SLEEP OFF" repetition="1">SLPOFF\x0D</Code>
<Code name="POWER Z2 OFF" repetition="1">Z2OFF\x0D</Code>
<Code name="POWER Z2 ON" repetition="1">Z2ON\x0D</Code>
<Code name="POWER Z2 STANDBY QUERY" repetition="1">Z2STBY?\x0D</Code>
<Code name="POWER Z2 STANDBY 1HR" repetition="1">Z2STBY1H\x0D</Code>
<Code name="POWER Z2 STANDBY 2HR" repetition="1">Z2STBY2H\x0D</Code>
<Code name="POWER Z2 STANDBY 4HR" repetition="1">Z2STBY4H\x0D</Code>
<Code name="POWER Z2 STANDBY OFF" repetition="1">Z2STBYOFF\x0D</Code>
<Code name="POWER Z2 SLEEP 120" repetition="1">Z2SLP120\x0D</Code>
<Code name="POWER Z2 SLEEP OFF" repetition="1">Z2SLPOFF\x0D</Code>
<Code name="MENU - SETUP OFF" repetition="1">MNMEN OFF\x0D</Code>
<Code name="MENU - SETUP ON" repetition="1">MNMEN ON\x0D</Code>
<Code name="MENU - RETURN" repetition="1">MNRTN\x0D</Code>
<Code name="MENU - OPTION" repetition="1">MNOPT\x0D</Code>
<Code name="MENU - INFO" repetition="1">MNINF\x0D</Code>
<Code name="MENU - CHANNEL LEVEL" repetition="1">MNCHL\x0D</Code>
<Code name="CURSOR DOWN" repetition="1">MNCDN\x0D</Code>
<Code name="CURSOR ENTER" repetition="1">MNENT\x0D</Code>
<Code name="CURSOR LEFT" repetition="1">MNCLT\x0D</Code>
<Code name="CURSOR RIGHT" repetition="1">MNCRT\x0D</Code>
<Code name="CURSOR UP" repetition="1">MNCUP\x0D</Code>
<Code name="HDMI AUDIO OP QUERY" repetition="1">VSAUDIO ?\x0D</Code>
<Code name="HDMI AUDIO OUTPUT TO AMP" repetition="1">VSAUDIO AMP\x0D</Code>
<Code name="HDMI AUDIO OUTPUT TO TV" repetition="1">VSAUDIO TV\x0D</Code>
<Code name="INPUT STATUS QUERY" repetition="1">SI?\x0D</Code>
<Code name="INPUT PHONO" repetition="1">SIPHONO\x0D</Code>
<Code name="INPUT CD" repetition="1">SICD\x0D</Code>
<Code name="INPUT DVD" repetition="1">SIDVD\x0D</Code>
<Code name="INPUT BD" repetition="1">SIBD\x0D</Code>
<Code name="INPUT TV" repetition="1">SITV\x0D</Code>
<Code name="INPUT SAT/CBL" repetition="1">SISAT/CBL\x0D</Code>
<Code name="INPUT MEDIA PLAYER" repetition="1">SIMPLAY\x0D</Code>
<Code name="INPUT GAME" repetition="1">SIGAME\x0D</Code>
<Code name="INPUT TUNER" repetition="1">SITUNER\x0D</Code>
<Code name="INPUT 8K" repetition="1">SI8K\x0D</Code>
<Code name="INPUT AUX1" repetition="1">SIAUX1\x0D</Code>
<Code name="INPUT NET" repetition="1">SINET\x0D</Code>
<Code name="SOUND IP MODE QUERY" repetition="1">SD ?\x0D</Code>
<Code name="SOUND INPUT MODE - AUTO" repetition="1">SDAUTO\x0D</Code>
<Code name="SOUND INPUT MODE - HDMI" repetition="1">SDHDMI\x0D</Code>
<Code name="SOUND INPUT MODE - ANALOG" repetition="1">SDANALOG\x0D</Code>
<Code name="SOUND INPUT MODE - DIGITAL" repetition="1">SDDIGITAL\x0D</Code>
<Code name="MUTE QUERY" repetition="1">MU ?\x0D</Code>
<Code name="MUTE ON" repetition="1">MUON\x0D</Code>
<Code name="VOLUME LEVEL QUERY" repetition="1">MV?\x0D</Code>
<Code name="VOLUME DOWN" repetition="1">MVDOWN\x0D</Code>
<Code name="VOLUME UP" repetition="1">MVUP\x0D</Code>
<Code name="VOL SPEAKER LEVEL QUERY" repetition="1">CV?\x0D</Code>
<Code name="VOL FRONT L DOWN" repetition="1">CVFL DOWN\x0D</Code>
<Code name="VOL FRONT L UP" repetition="1">CVFL UP\x0D</Code>
<Code name="VOL CENTER DOWN" repetition="1">CVC DOWN\x0D</Code>
<Code name="VOL CENTER UP" repetition="1">CVC UP\x0D</Code>
<Code name="VOL FRONT R DOWN" repetition="1">CVFR DOWN\x0D</Code>
<Code name="VOL FRONT R UP" repetition="1">CVFR UP\x0D</Code>
<Code name="VOL FRONT WIDE L DOWN" repetition="1">CVFWL DOWN\x0D</Code>
<Code name="VOL FRONT WIDE L UP" repetition="1">CVFWL UP\x0D</Code>
<Code name="VOL FRONT WIDE R DOWN" repetition="1">CVFWR DOWN\x0D</Code>
<Code name="VOL FRONT WIDE R UP" repetition="1">CVFWR UP\x0D</Code>
<Code name="VOL FRONT HEIGHT L DOWN" repetition="1">CVFHL DOWN\x0D</Code>
<Code name="VOL FRONT HEIGHT L UP" repetition="1">CVFHL UP\x0D</Code>
<Code name="VOL FRONT HEIGHT R DOWN" repetition="1">CVFHR DOWN\x0D</Code>
<Code name="VOL FRONT HEIGHT R UP" repetition="1">CVFHR UP\x0D</Code>
<Code name="VOL SURR BACK L DOWN" repetition="1">CVSBL DOWN\x0D</Code>
<Code name="VOL SURR BACK L UP" repetition="1">CVSBL UP\x0D</Code>
<Code name="VOL SURR BACK R DOWN" repetition="1">CVSBR DOWN\x0D</Code>
<Code name="VOL SURR BACK R UP" repetition="1">CVSBR UP\x0D</Code>
<Code name="VOL SURR L DOWN" repetition="1">CVSL DOWN\x0D</Code>
<Code name="VOL SURR L UP" repetition="1">CVSL UP\x0D</Code>
<Code name="VOL SURR R DOWN" repetition="1">CVSR DOWN\x0D</Code>
<Code name="VOL SURR R UP" repetition="1">CVSR UP\x0D</Code>
<Code name="VOL SUBWOOFER DOWN" repetition="1">CVSW DOWN\x0D</Code>
<Code name="VOL SUBWOOFER UP" repetition="1">CVSW UP\x0D</Code>
<Code name="VOL SUB ON/OFF QUERY" repetition="1">PSSWR ?\x0D</Code>
<Code name="VOL SUBWOOFER ON" repetition="1">PSSWR ON\x0D</Code>
<Code name="VOL SUBWOOFER OFF" repetition="1">PSSWR OFF\x0D</Code>
<Code name="LEVEL DOLBY L DOWN" repetition="1">CVFDL DOWN\x0D</Code>
<Code name="LEVEL DOLBY L UP" repetition="1">CVFDL UP\x0D</Code>
<Code name="LEVEL CENTER QUERY" repetition="1">PSCLV ?\x0D</Code>
<Code name="LEVEL CENTER DOWN" repetition="1">PSCLV DOWN\x0D</Code>
<Code name="LEVEL CENTER UP" repetition="1">PSCLV UP\x0D</Code>
<Code name="LEVEL DIALOG QUERY" repetition="1">PSDIC ?\x0D</Code>
<Code name="LEVEL DIALOG DOWN" repetition="1">PSDIC DOWN\x0D</Code>
<Code name="LEVEL DIALOG UP" repetition="1">PSDIC UP\x0D</Code>
<Code name="LEVEL DOLBY R DOWN" repetition="1">CVFDR DOWN\x0D</Code>
<Code name="LEVEL DOLBY R UP" repetition="1">CVFDR UP\x0D</Code>
<Code name="LEVEL DOLBY BACK L DOWN" repetition="1">CVBDL DOWN\x0D</Code>
<Code name="LEVEL DOLBY BACK L UP" repetition="1">CVBDL UP\x0D</Code>
<Code name="LEVEL DOLBY SURR L DOWN" repetition="1">CVSDL DOWN\x0D</Code>
<Code name="LEVEL DOLBY SURR L UP" repetition="1">CVSDL UP\x0D</Code>
<Code name="LEVEL LFE QUERY" repetition="1">PSLFE ?\x0D</Code>
<Code name="LEVEL LFE DOWN" repetition="1">PSLFE DOWN\x0D</Code>
<Code name="LEVEL LFE UP" repetition="1">PSLFE DOWN\x0D</Code>
<Code name="LEVEL DOLBY SURR R DOWN" repetition="1">CVSDR DOWN\x0D</Code>
<Code name="LEVEL DOLBY SURR R UP" repetition="1">CVSDR UP\x0D</Code>
<Code name="LEVEL DOLBY BACK R DOWN" repetition="1">CVBDR DOWN\x0D</Code>
<Code name="LEVEL DOLBY BACK R UP" repetition="1">CVBDR UP\x0D</Code>
<Code name="TONE CONTROL QUERY" repetition="1">PSTONE CTRL ?\x0D</Code>
<Code name="TONE CONTROL OFF" repetition="1">PSTONE CTRL OFF\x0D</Code>
<Code name="TONE CONTROL ON" repetition="1">PSTONE CTRL ON\x0D</Code>
<Code name="TONE BASS QUERY" repetition="1">PSBAS ?\x0D</Code>
<Code name="TONE BASS UP" repetition="1">PSBAS UP\x0D</Code>
<Code name="TONE BASS DOWN" repetition="1">PSBAS DOWN\x0D</Code>
<Code name="TONE TREBLE QUERY" repetition="1">PSTRE ?\x0D</Code>
<Code name="TONE TREBLE UP" repetition="1">PSTRE UP\x0D</Code>
<Code name="TONE TREBLE DOWN" repetition="1">PSTRE DOWN\x0D</Code>
<Code name="TONE LOUD QUERY" repetition="1">PSLOM ?\x0D</Code>
<Code name="TONE LOUD ON" repetition="1">PSLOM ON\x0D</Code>
<Code name="TONE LOUD OFF" repetition="1">PSLOM OFF\x0D</Code>
<Code name="TONE BASS SYNC QUERY" repetition="1">PSBSC ?\x0D</Code>
<Code name="TONE BASS SYNC UP" repetition="1">PSBSC UP\x0D</Code>
<Code name="TONE BASS SYNC DOWN" repetition="1">PSBSC DOWN\x0D</Code>
<Code name="SURROUND MODE QUERY" repetition="1">MS?\x0D</Code>
<Code name="SURROUND MODE - MOVIE" repetition="1">MSMOVIE\x0D</Code>
<Code name="SURROUND MODE - MUSIC" repetition="1">MSMUSIC\x0D</Code>
<Code name="SURROUND MODE - GAME" repetition="1">MSGAME\x0D</Code>
<Code name="SURROUND MODE - DIRECT" repetition="1">MSDIRECT\x0D</Code>
<Code name="SURROUND MODE - PURE DIRECT" repetition="1">MSPURE DIRECT\x0D</Code>
<Code name="SURROUND MODE - STEREO" repetition="1">MSSTEREO\x0D</Code>
<Code name="SURROUND MODE - AUTO" repetition="1">MSAUTO\x0D</Code>
<Code name="SURROUND MODE - STANDARD" repetition="1">MSSTANDARD\x0D</Code>
<Code name="SURROUND MODE - DOLBY DIGITAL" repetition="1">MSDOLBY DIGITAL\x0D</Code>
<Code name="SURROUND MODE - DTS SURROUND" repetition="1">MSDTS SURROUND\x0D</Code>
<Code name="SURROUND MODE - AURO 3D" repetition="1">MSAURO3D\x0D</Code>
<Code name="SURROUND MODE - AURO 2D SURROUND" repetition="1">MSAURO2DSURR\x0D</Code>
<Code name="SURROUND MODE - MULTI CH. STEREO" repetition="1">MSMCH STEREO\x0D</Code>
<Code name="SURROUND MODE - ROCK ARENA" repetition="1">MSROCK ARENA\x0D</Code>
<Code name="SURROUND MODE - JAZZ CLUB" repetition="1">MSJAZZ CLUB\x0D</Code>
<Code name="SURROUND MODE - MONO MOVIE" repetition="1">MSMONO MOVIE\x0D</Code>
<Code name="SURROUND MODE - MATRIX" repetition="1">MSMATRIX\x0D</Code>
<Code name="SURROUND MODE - VIDEO GAME" repetition="1">MSVIDEO GAME\x0D</Code>
<Code name="SURROUND MODE - VIRTUAL" repetition="1">MSVIRTUAL\x0D</Code>
<Code name="AUDIO OPT VIRT QUERY" repetition="1">PSSPV ?\x0D</Code>
<Code name="AUDIO OPTION - VIRTUALISER ON" repetition="1">PSSPV ON\x0D</Code>
<Code name="AUDIO OPTION - VIRTUALISER OFF" repetition="1">PSSPV OFF\x0D</Code>
<Code name="AUDIO OPT NEURAL QUERY" repetition="1">PSNEURAL ?\x0D</Code>
<Code name="AUDIO OPTION - NEURAL:X ON" repetition="1">PSNEURAL ON\x0D</Code>
<Code name="AUDIO OPTION - NEURAL:X OFF" repetition="1">PSNEURAL OFF\x0D</Code>
<Code name="AUDIO OPT IMAX QUERY" repetition="1">PSIMAX ?\x0D</Code>
<Code name="AUDIO OPT IMAX AUD QUERY" repetition="1">PSIMAXAUD ?\x0D</Code>
<Code name="AUDIO OPTION - IMAX AUTO" repetition="1">PSIMAX AUTO\x0D</Code>
<Code name="AUDIO OPTION - IMAX ON" repetition="1">PSIMAX ON\x0D</Code>
<Code name="AUDIO OPTION - IMAX OFF" repetition="1">PSIMAX OFF\x0D</Code>
<Code name="AUDIO OPTION - IMAX AUDIO AUTO" repetition="1">PSIMAXAUD AUTO\x0D</Code>
<Code name="AUDIO OPTION - IMAX AUDIO MANUAL" repetition="1">PSIMAXAUD MANUAL\x0D</Code>
<Code name="AUDIO OPT IMAX SUB QUERY" repetition="1">PSIMAXSWM ?\x0D</Code>
<Code name="AUDIO OPTION - IMAX SUB MODE ON" repetition="1">PSIMAXSWM ON\x0D</Code>
<Code name="AUDIO OPTION - IMAX SUB MODE OFF" repetition="1">PSIMAXSWM OFF\x0D</Code>
<Code name="AUDIO OPT CINE EQ QUERY" repetition="1">PSCINEMA EQ. ?\x0D</Code>
<Code name="AUDIO OPTION - CINEMA EQ ON" repetition="1">PSCINEMA EQ.ON\x0D</Code>
<Code name="AUDIO OPTION - CINEMA EQ OFF" repetition="1">PSCINEMA EQ.OFF\x0D</Code>
<Code name="AUDIO OPT MULTEQ QUERY" repetition="1">PSMULTEQ: ?\x0D</Code>
<Code name="AUDIO OPTION - MultEQ Audyssey" repetition="1">PSMULTEQ:AUDYSSEY\x0D</Code>
<Code name="AUDIO OPTION - MultEQ L/R Bypass" repetition="1">PSMULTEQ:BYP.LR\x0D</Code>
<Code name="AUDIO OPTION - MultEQ Flat" repetition="1">PSMULTEQ:FLAT\x0D</Code>
<Code name="AUDIO OPTION - MultEQ OFF" repetition="1">PSMULTEQ:OFF\x0D</Code>
<Code name="AUDIO OPT DYNAMIC EQ QUERY" repetition="1">PSDYNEQ ?\x0D</Code>
<Code name="AUDIO OPTION - DYNAMIC EQ ON" repetition="1">PSDYNEQ ON\x0D</Code>
<Code name="AUDIO OPTION - DYNAMIC EQ OFF" repetition="1">PSDYNEQ OFF\x0D</Code>
<Code name="AUDIO OPT REF OFFSET QUERY" repetition="1">PSREFLEV ?\x0D</Code>
<Code name="AUDIO OPTION - REF OFFSET 0dB" repetition="1">PSREFLEV 0\x0D</Code>
<Code name="AUDIO OPTION - REF OFFSET 5dB" repetition="1">PSREFLEV 5\x0D</Code>
<Code name="AUDIO OPTION - REF OFFSET 10dB" repetition="1">PSREFLEV 10\x0D</Code>
<Code name="AUDIO OPTION - REF OFFSET 15dB" repetition="1">PSREFLEV 15\x0D</Code>
<Code name="AUDIO OPT DYN VOL QUERY" repetition="1">PSDYNVOL ?\x0D</Code>
<Code name="AUDIO OPTION - DYNAMIC VOL HEAVY" repetition="1">PSDYNVOL HEV\x0D</Code>
<Code name="AUDIO OPTION - DYNAMIC VOL MEDIUM" repetition="1">PSDYNVOL MED\x0D</Code>
<Code name="AUDIO OPTION - DYNAMIC VOL LIGHT" repetition="1">PSDYNVOL LIT\x0D</Code>
<Code name="AUDIO OPTION - DYNAMIC VOL OFF" repetition="1">PSDYNVOL OFF\x0D</Code>
<Code name="AUDIO OPT AUD LFC QUERY" repetition="1">PSLFC ?\x0D</Code>
<Code name="AUDIO OPTION - AUDYSSEY LFC ON" repetition="1">PSLFC ON\x0D</Code>
<Code name="AUDIO OPTION - AUDYSSEY LFC OFF" repetition="1">PSLFC OFF\x0D</Code>
<Code name="AUDIO OPT CONT QUERY" repetition="1">PSCNTAMT ?\x0D</Code>
<Code name="AUDIO OPTION - CONTAINMENT UP" repetition="1">PSCNTAMT UP\x0D</Code>
<Code name="AUDIO OPTION - CONTAINMENT DOWN" repetition="1">PSCNTAMT DOWN\x0D</Code>
<Code name="AUDIO GR EQ QUERY" repetition="1">PSGEQ ?\x0D</Code>
<Code name="AUDIO OPTION - GRAPHIC EQ ON" repetition="1">PSGEQ ON\x0D</Code>
<Code name="AUDIO OPTION - GRAPHIC EQ OFF" repetition="1">PSGEQ OFF\x0D</Code>
<Code name="AUDIO HPEQ QUERY" repetition="1">PSHEQ ?\x0D</Code>
<Code name="AUDIO OPTION - HEADPHONE EQ ON" repetition="1">PSHEQ ON\x0D</Code>
<Code name="AUDIO OPTION - HEADPHONE EQ OFF" repetition="1">PSHEQ OFF\x0D</Code>
<Code name="AUDIO DRC QUERY" repetition="1">PSDRC ?\x0D</Code>
<Code name="AUDIO OPTION - DRC AUTO" repetition="1">PSDRC AUTO\x0D</Code>
<Code name="AUDIO OPTION - DRC LOW" repetition="1">PSDRC LOW\x0D</Code>
<Code name="AUDIO OPTION - DRC MID" repetition="1">PSDRC MID\x0D</Code>
<Code name="AUDIO OPTION - DRC HIGH" repetition="1">PSDRC HI\x0D</Code>
<Code name="AUDIO OPTION - DRC OFF" repetition="1">PSDRC OFF\x0D</Code>
<Code name="AUDIO OPT EFFECT QUERY" repetition="1">PSEFF ?\x0D</Code>
<Code name="AUDIO OPTION - EFFECT ON" repetition="1">PSEFF ON\x0D</Code>
<Code name="AUDIO OPTION - EFFECT OFF" repetition="1">PSEFF OFF\x0D</Code>
<Code name="AUDIO OPTION - EFFECT UP" repetition="1">PSEFF UP\x0D</Code>
<Code name="AUDIO OPTION - EFFECT DOWN" repetition="1">PSEFF DOWN\x0D</Code>
<Code name="AUDIO DEL QUERY" repetition="1">PSDEL ?\x0D</Code>
<Code name="AUDIO OPTION - DELAY TIME UP" repetition="1">PSDEL UP\x0D</Code>
<Code name="AUDIO OPTION - DELAY TIME DOWN" repetition="1">PSDEL DOWN\x0D</Code>
<Code name="AUDIO DEL2 QUERY" repetition="1">PSDELAY ?\x0D</Code>
<Code name="AUDIO OPTION - AUDIO DELAY UP" repetition="1">PSDELAY UP\x0D</Code>
<Code name="AUDIO OPTION - AUDIO DELAY DOWN" repetition="1">PSDELAY DOWN\x0D</Code>
<Code name="AUDIO OPT REST QUERY" repetition="1">PSRSTR ?\x0D</Code>
<Code name="AUDIO OPTION - RESTORER OFF" repetition="1">PSRSTR OFF\x0D</Code>
<Code name="AUDIO OPTION - RESTORER LOW" repetition="1">PSRSTR LOW\x0D</Code>
<Code name="AUDIO OPTION - RESTORER MED" repetition="1">PSRSTR MED\x0D</Code>
<Code name="AUDIO OPTION - RESTORER HI" repetition="1">PSRSTR HI\x0D</Code>
<Code name="AUDIO OPT AURO PST QUERY" repetition="1">PSAUROPR ?\x0D</Code>
<Code name="AUDIO OPTION - AUROMATIC 3D SMALL" repetition="1">PSAUROPR SMA\x0D</Code>
<Code name="AUDIO OPTION - AUROMATIC 3D MED" repetition="1">PSAUROPR MED\x0D</Code>
<Code name="AUDIO OPTION - AUROMATIC 3D LARGE" repetition="1">PSAUROPR LAR\x0D</Code>
<Code name="AUDIO OPTION - AUROMATIC 3D SPEECH" repetition="1">PSAUROPR SPE\x0D</Code>
<Code name="AUDIO OPTION - AUROMATIC 3D MOVIE" repetition="1">PSAUROPR MOV\x0D</Code>
<Code name="AUDIO OPT AURO STR QUERY" repetition="1">PSAUROST ?\x0D</Code>
<Code name="AUDIO OPTION - AUROMATIC 3D UP" repetition="1">PSAUROST UP\x0D</Code>
<Code name="AUDIO OPTION - AUROMATIC 3D DOWN" repetition="1">PSAUROST DOWN\x0D</Code>
<Code name="AUDIO OPT AURO MODE QUERY" repetition="1">PSAUROMODE ?\x0D</Code>
<Code name="AUDIO OPTION - AUROMATIC 3D DIRECT" repetition="1">PSAUROMODE DRCT\x0D</Code>
<Code name="AUDIO OPTION - AUROMATIC 3D EXPAND" repetition="1">PSAUROMODE EXP\x0D</Code>
<Code name="VIDEO SIGNAL ASPECT QUERY" repetition="1">VSASP ?\x0D</Code>
<Code name="VIDEO SIGNAL ASPECT RATIO - NORMAL" repetition="1">VSASPRNRM\x0D</Code>
<Code name="VIDEO SIGNAL ASPECT RATIO - FULL" repetition="1">VSASPFUL\x0D</Code>
<Code name="VIDEO SIGNAL MONITOR QUERY" repetition="1">VSMONI ?\x0D</Code>
<Code name="VIDEO SIGNAL MODE - MONITOR OUT 1" repetition="1">VSMONI1\x0D</Code>
<Code name="VIDEO SIGNAL MODE - MONITOR OUT 2" repetition="1">VSMONI2\x0D</Code>
<Code name="VIDEO SIGNAL MODE - AUTO" repetition="1">VSMONIAUTO\x0D</Code>
<Code name="VIDEO SIGNAL RES QUERY" repetition="1">VSSC ?\x0D</Code>
<Code name="VIDEO SIGNAL - 480p_576p" repetition="1">VSSC48P\x0D</Code>
<Code name="VIDEO SIGNAL - 1080i" repetition="1">VSSC10I\x0D</Code>
<Code name="VIDEO SIGNAL - 720p" repetition="1">VSSC75P\x0D</Code>
<Code name="VIDEO SIGNAL - 1080p" repetition="1">VSSC10P\x0D</Code>
<Code name="VIDEO SIGNAL - 4K (24/60/50)" repetition="1">VSSC4K\x0D</Code>
<Code name="VIDEO SIGNAL - 8K" repetition="1">VSSC8K\x0D</Code>
<Code name="VIDEO SIGNAL - AUTO" repetition="1">VSSCAUTO\x0D</Code>
<Code name="VIDEO SIGNAL RES HDMI QUERY" repetition="1">VSSCH ?\x0D</Code>
<Code name="VIDEO SIGNAL HDMI - 480P_576P" repetition="1">VSSCH48P\x0D</Code>
<Code name="VIDEO SIGNAL HDMI - 1080i" repetition="1">VSSCH10I\x0D</Code>
<Code name="VIDEO SIGNAL HDMI - 720p" repetition="1">VSSCH72P\x0D</Code>
<Code name="VIDEO SIGNAL HDMI - 1080P" repetition="1">VSSCH10P\x0D</Code>
<Code name="VIDEO SIGNAL HDMI - 4K" repetition="1">VSSCH4K\x0D</Code>
<Code name="VIDEO SIGNAL HDMI - 8K" repetition="1">VSSCH8K\x0D</Code>
<Code name="VIDEO SIGNAL HDMI - AUTO" repetition="1">VSSCHAUTO\x0D</Code>
<Code name="VIDEO PROCESSING MODE QUERY" repetition="1">VSVPM ?\x0D</Code>
<Code name="VIDEO PROCESSING MODE - AUTO" repetition="1">VSVPMAUTO\x0D</Code>
<Code name="VIDEO PROCESSING MODE - GAME" repetition="1">VSVPMGAME\x0D</Code>
<Code name="VIDEO PROCESSING MODE - MOVIE" repetition="1">VSVPMMOVI\x0D</Code>
<Code name="VIDEO SELECT QUERY" repetition="1">SV ?\x0D</Code>
<Code name="VIDEO SELECT MODE - DVD" repetition="1">SVDVD\x0D</Code>
<Code name="VIDEO SELECT MODE - BD" repetition="1">SVBD\x0D</Code>
<Code name="VIDEO SELECT MODE - TV" repetition="1">SVTV\x0D</Code>
<Code name="VIDEO SELECT MODE - SAT_CBL" repetition="1">SVSAT/CBL\x0D</Code>
<Code name="VIDEO SELECT MODE - MPLAY" repetition="1">SVMPLAY\x0D</Code>
<Code name="VIDEO SELECT MODE - GAME" repetition="1">SVGAME\x0D</Code>
<Code name="VIDEO SELECT MODE - 8K" repetition="1">SV8K\x0D</Code>
<Code name="VIDEO SELECT MODE - AUX 1" repetition="1">SVAUX1\x0D</Code>
<Code name="VIDEO SELECT MODE - CD" repetition="1">SVCD\x0D</Code>
<Code name="VIDEO SELECT MODE -ON" repetition="1">SVON\x0D</Code>
<Code name="VIDEO SELECT MODE -OFF" repetition="1">SVOFF\x0D</Code>
<Code name="PICTURE MODE QUERY" repetition="1">PV ?\x0D</Code>
<Code name="PICTURE - MODE OFF" repetition="1">PVOFF\x0D</Code>
<Code name="PICTURE - MODE STANDARD" repetition="1">PVSTD\x0D</Code>
<Code name="PICTURE - MODE MOVIE" repetition="1">PVMOV\x0D</Code>
<Code name="PICTURE - MODE VIVID" repetition="1">PVVVD\x0D</Code>
<Code name="PICTURE - MODE STREAM" repetition="1">PVSTM\x0D</Code>
<Code name="PICTURE - MODE CUSTOM" repetition="1">PVCTM\x0D</Code>
<Code name="PICTURE - MODE ISF DAY" repetition="1">PVDAY\x0D</Code>
<Code name="PICTURE - MODE ISF NIGHT" repetition="1">PVNGT\x0D</Code>
<Code name="PICTURE DNR QUERY" repetition="1">PVDNR ?\x0D</Code>
<Code name="PICTURE - DNR OFF" repetition="1">PVDNR OFF\x0D</Code>
<Code name="PICTURE - DNR LOW" repetition="1">PVDNR LOW\x0D</Code>
<Code name="PICTURE - DNR MID" repetition="1">PVDNR MID\x0D</Code>
<Code name="PICTURE - DNR HI" repetition="1">PVDNR HI\x0D</Code>
<Code name="PICTURE CONTRAST QUERY" repetition="1">PVCN ?\x0D</Code>
<Code name="PICTURE - CONTRAST UP" repetition="1">PVCN UP\x0D</Code>
<Code name="PICTURE - CONTRAST 50" repetition="1">PVCN 050\x0D</Code>
<Code name="PICTURE - CONTRAST DOWN" repetition="1">PVCN DOWN\x0D</Code>
<Code name="PICTURE BRIGHTNESS QUERY" repetition="1">PVBR ?\x0D</Code>
<Code name="PICTURE - BRIGHTNESS UP" repetition="1">PVBR UP\x0D</Code>
<Code name="PICTURE - BRIGHTNESS 50" repetition="1">PVBR 050\x0D</Code>
<Code name="PICTURE - BRIGHTNESS DOWN" repetition="1">PVBR DOWN\x0D</Code>
<Code name="PICTURE SATURATION QUERY" repetition="1">PVST ?\x0D</Code>
<Code name="PICTURE - SATURATION UP" repetition="1">PVST DOWN\x0D</Code>
<Code name="PICTURE - SATURATION 50" repetition="1">PVST 050\x0D</Code>
<Code name="PICTURE - SATURATION DOWN" repetition="1">PVST DOWN\x0D</Code>
<Code name="PICTURE ENHANCER QUERY" repetition="1">PVENH ?\x0D</Code>
<Code name="PICTURE - ENHANCER UP" repetition="1">PVENH UP\x0D</Code>
<Code name="PICTURE - ENHANCER 0" repetition="1">PVENH 0\x0D</Code>
<Code name="PICTURE - ENHANCER DOWN" repetition="1">PVENH DOWN\x0D</Code>
<Code name="BLUETOOTH QUERY" repetition="1">BTTX ?\x0D</Code>
<Code name="BLUETOOTH ON" repetition="1">BTTX ON\x0D</Code>
<Code name="BLUETOOTH OFF" repetition="1">BTTX OFF\x0D</Code>
<Code name="BLUETOOTH ONLY" repetition="1">BTTX BT\x0D</Code>
<Code name="BLUETOOTH + SPEAKERS" repetition="1">BTTX SP\x0D</Code>
<Code name="Z2 QUERY" repetition="1">Z2?\x0D</Code>
<Code name="Z2 MODE CANCEL" repetition="1">Z2SOURCE\x0D</Code>
<Code name="Z2 PHONO" repetition="1">Z2PHONO\x0D</Code>
<Code name="Z2 CD" repetition="1">Z2CD\x0D</Code>
<Code name="Z2 DVD" repetition="1">Z2DVD\x0D</Code>
<Code name="Z2 BD" repetition="1">Z2BD\x0D</Code>
<Code name="Z2 TV" repetition="1">Z2TV\x0D</Code>
<Code name="Z2 SAT/CBL" repetition="1">Z2SAT/CBL\x0D</Code>
<Code name="Z2 MEDIA PLAYER" repetition="1">Z2MPLAY\x0D</Code>
<Code name="Z2 GAME" repetition="1">Z2GAME\x0D</Code>
<Code name="Z2 TUNER" repetition="1">Z2TUNER\x0D</Code>
<Code name="Z2 8K" repetition="1">Z28K\x0D</Code>
<Code name="Z2 AUX1" repetition="1">Z2AUX1\x0D</Code>
<Code name="Z2 NET" repetition="1">Z2NET\x0D</Code>
<Code name="Z2 BT" repetition="1">Z2BT\x0D</Code>
<Code name="Z2 MUTE QUERY" repetition="1">Z2MU?\x0D</Code>
<Code name="Z2 MUTE ON" repetition="1">Z2MUON\x0D</Code>
<Code name="Z2 MUTE OFF" repetition="1">Z2MUOFF\x0D</Code>
</CodesType>
<CodesType name="Database Codes"> </CodesType>
</Device>
