Is it possible to send any command to the AVR?
Re: Is it possible to send any command to the AVR?
2 years 1 month ago
#3130
Thanks again! I think even I can make that work!
Cheers
Ben
#3131
You can use an Automation Rule to look for change of "DVD" and then do a SetVar with "BluRay" to same value.
EDIT...looks like Dave already got it for ya.
The following user(s) said Thank You: allonis@bendavies.eu
2 years 1 month ago
#3134
I just pushed an update to the Denon driver. It will now automatically query the AVR for all possible status and then create the appropriate server variables. I followed, what I believe to be, the most recent Denon protocol document. Hopefully it gets you the info you are looking for.
Thanks Dave I appreciate you adding this! This is something that I've been wishing for for awhile now.
#3135
Hi Dave,
I'm displaying the Denon server variables {{av_<id>_source}} and {{av_<id>_surround_mode}}.
These are largely working - but SOME of the responses from them are not showing.
When watching the debug, I can see the correct source and surround mode commands triggering, and can then see the variables running.
The variable TX commands are sent correctly, and I can see the expected RX responses in the debug log.
For certain responses, the variable doesn't display on my page.
Any idea why this could be?
It seems that the 2 character source responses are being missed - all the source responses that have 3 or more responses are picked up - possibly relevant!
Some examples (these don't display the variable on my page):
27/08/2024 18:44:20.44 · DEBUG · Server.doCommand - AV|1~Source~CD from iruled-fx-e8q6
27/08/2024 18:44:20.44 · DEBUG · Denon.doCommand - Cmd=[1~Source~CD] Client=[iruled-fx-e8q6]
27/08/2024 18:44:20.44 · DEBUG · Denon.TX: (1) - SICD
27/08/2024 18:44:21.44 · DEBUG · Denon.RX - <<SICD>>
27/08/2024 18:49:45.49 · DEBUG · Server.doCommand - AV|1~Source~BD from iruled-fx-e8q6
27/08/2024 18:49:45.49 · DEBUG · Denon.doCommand - Cmd=[1~Source~BD] Client=[iruled-fx-e8q6]
27/08/2024 18:49:45.49 · DEBUG · Denon.TX: (1) - SIBD
27/08/2024 18:49:46.49 · DEBUG · Denon.RX - <<SIBD>>
27/08/2024 18:57:59.57 · DEBUG · Server.doCommand - AV|1~Source~TV from iruled-fx-e8q6
27/08/2024 18:57:59.57 · DEBUG · Denon.doCommand - Cmd=[1~Source~TV] Client=[iruled-fx-e8q6]
27/08/2024 18:57:59.57 · DEBUG · Denon.TX: (1) - SITV
27/08/2024 18:58:10.58 · DEBUG · Denon.RX - <<SITV>>
27/08/2024 19:00:21.00 · DEBUG · Server.doCommand - AV|1~Source~8K from iruled-fx-e8q6
27/08/2024 19:00:21.00 · DEBUG · Denon.doCommand - Cmd=[1~Source~8K] Client=[iruled-fx-e8q6]
27/08/2024 19:00:21.00 · DEBUG · Denon.TX: (1) - SI8K
27/08/2024 19:00:22.00 · DEBUG · Denon.RX - <<SI8K>>
This one DOES display the variable on my page:
27/08/2024 18:47:08.47 · DEBUG · Server.doCommand - AV|1~Source~DVD from iruled-fx-e8q6
27/08/2024 18:47:08.47 · DEBUG · Denon.doCommand - Cmd=[1~Source~DVD] Client=[iruled-fx-e8q6]
27/08/2024 18:47:08.47 · DEBUG · Denon.TX: (1) - SIDVD
27/08/2024 18:47:09.47 · DEBUG · Denon.RX - <<SIDVD>>
I've setup automations to rename the responses as per your help above (thanks again!).
I'm showing both variables (source and sourcename) just to verify that my automations aren't the problem here!
I am getting an error ("Insufficent parameters for command") with my surroundmode automation, which stops the last few lines working - which I assume is because it has 55 lines (there are many potential responses!)  Is there a way around this - if it's a limitation?
Many thanks for your help - apologies for bombarding you!  Hope this makes sense...
Ben
Last edit: 2 years 1 month ago by allonis@bendavies.eu. Reason: Pasted lines missed line breaks!
2 years 2 weeks ago
#3327
@davep - if you have any possible solution/ comment to help me with my last post on this topic, it would be much appreciated - it doesn't seem there's anything I can do to make the two character source responses work - I think only you may be able to fix this!! (the longer source responses work perfectly!)
Many thanks!
2 years 2 weeks ago
#3335
Right you are it was ignoring two character responses.  The driver I just released eliminates that feature.
Time to create page: 0.336 seconds
