Select room issue
Select room issue
#791
I am thinking this started after updating to the latest version of MyServer. When I select a room I get the following error14/02/2024 19:10:09.10 · DEBUG · Server.doCommand - activate-room.activate-room.masterbr from moonlightdev-fx-fm4j14/02/2024 19:10:09.10 · WARN · Server.doCommand - Unknown command activate-room.activate-room.masterbr
Re: Select room issue
#795
Look in the Macros page. There is no macro by that name. That's the error you see. Change the room to call the correct activation macro.
#801
Agree, If I change the macro name to activate-room.activate-room.masterbr it works. The button was working with activate-room.masterbr earlier in the day,
#1073
Nothing is random (unless you intentionally make something random in a macro).
So, if the behaviour changed, then you changed something to make it change.
That's important so you can troubleshoot...ie: what did I change since then?
Open the macro that is firing (you can see which in event viewer) and then open that and see what it is doing (or trying to do).
