"If" statement help
"If" statement help
#1822
I know this is super simple, but it's not for me....  What is the correct syntax for a If, Then, Else Macro (or command).
If
Variable X = 0
then
AV|14.........
else
AV14,,,,,,,
I know how to set variables and call commands, just not sure on the correct syntax for the If statement.
Thanks in advance!
Re: "If" statement help
#1824
allonis.com/support/documentation?view=category&id=247
There is an example in that article.
That article needs a lot of updating and cleaning up but has most all of the basics.
#1825
Like this?
if|isequal##{{active_tivo}}##{{11}}##{{AV|{{active_tivo}}~Tivo##{{AV|{{active_tivo}}~Main
Check if the active tivo is 11 and if it is run the Tivo command and if not run the Main command.
Thanks for the link!
#1827
No, only put the server variables in curly braces.
if|isequal##{{active_tivo}}##11##AV|{{active_tivo}}~Tivo##AV|{{active_tivo}}~Main
The Tivo driver has a command AV|<id>~Tivo   but not a AV|<id>~Main command. Is Main a valid Tivo command? If so I'll add it in the driver.
#1829
Thanks!!!
"Main" was a mistype ...no action required.
Now I can go and implement my logic!
#2129
I saw this example in your docs.
If|isEQ##{{variable_x}}{{variable_y}}##onoff##do something interesting
In the example variable_x = on and variable_y=off
How does it know to parse ##onoff##  Shouldn't there be a delimiter between the values?  In my case the variables are 0 and 1 so it would be some combo of that. 00, 01,10 etc.
Thanks!
Time to create page: 0.887 seconds
