Hard buttons locked?
#2209
When I click on a hard button in myDesigner to open up commands its as though the button is locked. I cant see any obvious settings and was just wondering if any of you has had the same problem and been able to fix it?
Re: Hard buttons locked?
#2210
I get the occasional hiccup where when I try to edit the buttons on a page(scene or overlay) it won't open the editing pop-up, if I open another page that one will work correctly.. no rhyme or reason to which pages work and which don't. Closing mydesigner and reopening it seems to sort it out though.
#2212
Mine just refuses to open the popup box. In particular I'm trying to add macros to the F keys in the index, cabletv and shieldtv html files. Oddly the shieldtv file works. I've just randomly tried it with 10 files I'm not using and 8 didn't work but 2 did. Closing myDesigner down doesn't make it work again for me unfortunately
#2215
As a workaround can you edit the buttons in the "scene properties" window? That's the picture just to the left of the "copy objects"
2 years 5 months ago
#2227
Good shout. It's a bit tricky as you can only see a small amount of text at a time.
I'm feeling a bit disillusioned with it at the minute. Every time I touch it there's an issue and I know most of that is down to me and we knew what we were getting into but I'm close to putting it in a box for a few months and forgetting about it
#2228
Create your extensive macro.  Name your macro.  Save it.  Then, invoke the macro {{macroname}} from within myDesigner's button configuration entry form.
What OS is myDesigner running on?  Win 10 / 11?
Send us an email with your myDesigner TeamViewer Host ID / password and we will check it.
