Tutorials
russb@bellsouth.net's Avatar Topic Author
Tutorials
#2211
MyServer and SmartRemote are great products.  I used IRule and various Harmony remotes in the past, and I can see the potential here, but this has a much steeper learning curve.  Is there a tutorial that shows beginning to end setting up a "Watch Movie" activity for a home theater?   Would be helpful for us novices to see the workflow and steps needed to create an activity.  Also, any success in controlling a WiiM Pro Plus streamer?  Finally, when I add the Hue driver and get devices I use 144 license units of entries which exceeds my license units..  Appears to have an entry for every scene.  How can I reduce it to the few devices I need?  I know this is a fairly new product, but I am struggling to get started.  Thanks.
Re: Tutorials
#2214
Can't say I've used the hue driver since I don't have one but if you go into the hue driver by going to the drivers page and then clicking on "configure" for the hue driver it should list every device. There is an "enabled" column that show which ones are enabled and counting towards your license. If you click the pencil you should be able to uncheck the "enabled" checkbox at the top and click "save". Then that device won't count towards your license.
The following user(s) said Thank You: russb@bellsouth.net
Re: Tutorials
#2219
Please put your questions into the appropriate area of the forum so others can easily find the discussion.
Each driver should have it's own section.  If not, I will create one and move the posts.
Time to create page: 0.397 seconds
