Help with a Macro
Re: Help with a Macro
2 years 5 months ago
#2350
Yes I have a Panasonic TV. And I am using my smartremote to select the input of the HDFury which seems to work fine
#2351
The 2nd set of codes were the ones that worked for me and like you said there were just a handfull to copy
#2352
To everyone who reached out thank you - you guys are awesome. I had a bad day today but with your help I will go again and again until I nail it.
Neil
#2359
Neil
You'll get it!!!
#2369
I hope you don't mind me asking a really basic question about your post from yesterday. It makes a lot of sense and I have stripped everything back and started to build things slowly.
After following through and arriving at:
  • SetVariable|Bedroom_source~BedRoomSkyQ!
Where does this go? Does it form part of the source activation macro, does it get loaded against a hard button or as a command?
Thanks again
Neil
PhoenixF15E's Avatar
#2370
Just wondered if one of you kind souls could cast your eye over my macro and tell me where I'm going wrong. I have tried loading it at the project level, I have tried it on html files but it just doesn't work. When I look at the logs there is nothing being recorded
macro|AV|{{active_tv_{{clientname}}}}~Remote~INPUT HDMI 2!Control|1~SendIR~4K Diva~INPUTSEL0!activate-source.cabletv-bedroomskyq
Full Macro below
Macro|
// Source activation macro for BedroomSkyQ!
// activeroom_<clientname>!
SetActiveSource|BedroomSkyQ!
AV|{{{{activeroom_{{clientname}}}}_cabletv_id}}~SelectDevice!
// Uncomment if you need to make sure the display is always looking at the correct source!
SetVariable|{{actom_{{clientname}}}}_display_input~HDMI2//!
If|isGT##{{{{activeroom_{{clientname}}}}_display_id}}##0##AV|{{{{activeroom_{{clientname}}}}_display_id}}~power~on!
// Set display to specific source!
If|isNE##{{{{activeroom_{{clientname}}}}_display_input}}####AV|{{{{activeroom_{{clientname}}}}_display_id}}~source~{{{{activeroom_{{clientname}}}}_display_input}}!
// LoadScene|cabletv!
// fini
I assume your referring to my description of how to read a macro with an explanation of the curly brackets.  You don't need to do anything.  This statement is already a part of your activation macro.  I was just pointing out an example from your activation macro to show how to see what the commands actually do.  I wouldn't strip away the curly brackets.  They allow the code to be used in multiple rooms and remotes.
Here's how I would proceed.  First I would fix the misspelling in your activation macro line and put in the correct source:
  • SetVariable|{{actom_{{clientname}}}}_display_input~HDMI2!"
  • should be: "SetVariable|{{activeroom_{{clientname}}}}_display_input~INPUT HDMI 2!
  • Note the space between "HDMI" and "2"
Next I would do as bowlingbeeg suggests and take commands from the macro on the function key that set the input on your TV and VRRoom and move them to your activation macro.  Before you do this, I would make sure your TV command works.  Since you have a Panasonic TV, I assume you're using IR to control it.  If so, the command to change the input will need to change, as I mentioned earlier.  It will look something like:
  • Control|1~SendIR~Panasonic-Most Models~INPUT HDMI 2!
I would add just this command to a button on your SmartRemote for testing until you get it working.  Once it's working, it will need to be added to the activation macro.  It will change in the activation macro to use the variable I mentioned above, and will looking something like:
  • Control|1~SendIR~Panasonic-Most Models~{{activeroom_{{clientname}}}}_display_input!
Once the TV Input and VRRoom commands are working, add them to the macro like I show below in red and change the command on your function key to simply "activate-source.cabletv-bedroomskyq"
Macro|
SetVariable|{{activeroom_{{clientname}}}}_display_input~INPUT HDMI2//!
If|isNE##{{{{activeroom_{{clientname}}}}_display_input}}####Control|1~SendIR~Panasonic-Most Models~{{activeroom_{{clientname}}}}_display_input!
// fini
Last edit: 2 years 5 months ago by PhoenixF15E.
