Problem with 'OK' button in remote emulator?
2 years 5 months ago
#2529
I've been trying out the new Kodi driver using the smartremote emulator built-in to MyDesigner (as I still don't have hardware). There seems to be a problem with the 'OK' button not working in the emulator. By default it's programmed to execute the Kodi 'Select' command and it just doesn't work. I added the select command to the more ('...') button and it works there so it's not the Kodi driver that's at fault (I think). I also tried adding a different command to the 'OK' button that I knew worked elsewhere ('Left') and that didn't work either. So it looks like the 'OK' button just doesn't work in the emulator. I haven't been able to try it against any other sources or scenes.
Video capture of the behaviour to follow in the next message.
Re: Problem with 'OK' button in remote emulator?
#2530
Video of 'OK' button not working.
Last edit: 2 years 5 months ago by andrew.
#2536
Thanks for finding that. It has a "Return" in the command when it should have an "OK". It is fixed in the SmartRemote sample template that I will release later today.
Install the latest sample when it is released. Then, to fix the issue copy the overlay-remotebuttons.html and overlay-remotebuttons-preview.html files from the sample into your working SmartRemote project folder.
#2537
Excellent. Thanks - I will watch out for the new template.
Edited to add: Being an impatient sort I've made the change myself in the two template files (putting 'ok' instead of 'return' in the clientcmd code) and it works now. Great!
#2544
That's cheating ;)
