Feature Request: Import and Export projects/files/images
2 years 3 weeks ago
#3218
I'm not sure what the experience is like on Windows, but on Mac/Parallels, the experience around creating a backup is really painful. I just spent probably 20 minutes copying all of my custom resources into a new folder in myDesigner, and then when I did the update, somehow my folder got overwritten and deleted. I will need to rebuild the pages now.
It would be very helpful if I could download a page (I'm not sure how mac/parallels stores files, I wasn't able to find the underlying file), and then import the page after the update is finished.
Re: Feature Request: Import and Export projects/files/images
2 years 3 weeks ago
#3225
The pages that the smart remote uses aren't stored locally on the windows/mac system where you have MyDesigner installed. They are stored on the device running MyServer. If you wish to backup all of the pages for a specific template(or all templates) then go to the dashboard, click on the wizard hat. Then click the hammer button and look for the BackupTemplate server command. Then select "all templates" or the specific template you want to backup. After that then push the "execute" button. That will zip up all of the pages for you and store it out on MyServer in the "backups" folder. You can access that through samba using \\<ip_address_of_my_server>\myServer\backups\ From there you can copy it to your local system in case you ever need to restore the templates.
You can also backup the MyServer DB and license, as well as export all of your macros and automations using server commands listed in that dropdown menu.
2 years 3 weeks ago
#3234
