Connecting to myserver share on RPi from Windows 11 Pro
#907
I could have sworn I've seen discussion about this elsewhere, either in the forum or the documentation, but I can't find it now. Anyway, I finally gave in and while waiting for my rack mount server I've bought a Raspberry Pi 5 to try things out on. I got the myServer master image downloaded and booted off a USB drive fine, then ran into a hurdle while trying to connect to the share at \\<myIP>\myserver. After many hours of messing around and Googling it seems to be something to do with ever-tightening security on the Microsoft client side on my Windows 11 Pro PC's (it happens on all of them).
I can't just browse to the share in Windows File Explorer as it tries to connect with my logged in Windows user account which obviously doesn't work, and I can't get Windows Explorer to prompt for other credentials. The best I've got is if I reboot (to clear any previous cached failed connection attempts) then in a CMD window I can run
net use m: \\<myIP>\myserver /USER:WORKGROUP\allonis *
and it will prompt for the password then create a working mapped drive at m:\. I can then run myDesigner and in the config field for the share if I put "m:" it thankfully works, or at least it seems to. Windows File Explorer still won't browse to \\<myIP>\myserver though.
I messed around with so much last night I'm not sure what else was necessary now but I think I had to create a samba user on the RPi by running
sudo smbpassword -a allonis
Anyone else battling against Windows 11 Pro? I tried various group policy changes I found by Googling and none of them seem to let me browse to the share in Explorer - I have to use the command line and map a drive letter.
Last edit: 2 years 7 months ago by andrew. Reason: HTML stripping
Sat32's Avatar
Re: Connecting to myserver share on RPi from Windows 11 Pro
#910
do you have SMB 1.0 support turned on
Start menu type: "windows features"
select turn windows features on off
select smb file sharing support
#914
Yeah, sorry, I should have mentioned all the things I've tried. They include (reluctantly) enabling SMB1 CIFS client on the Windows PCs. No go. Thanks anyway for the suggestion.
#917
What does it say when you do this ?
Sat32's Avatar
#920
I ran into a issue like this with OMV
Uninstalling smb reboot then reinstall windows updates borks that stuff.
#921
Ah, that was what I was remembering. It's in the docs isn't it? But I couldn't find it. Mind you it was 2am so I was a bit bleary-eyed by then. Anyway I'm afraid that has the same effect as typing the share into the File Explorer path bar - absolutely nothing happens (except the run dialog disappears in this case).
Time to create page: 0.330 seconds
