Master Image Issue? (Crashing)
2 years 2 months ago
#3085
I've installed the master image on two totally separate hosts (no shared HW) and the behavior is the same...it works fine, and crashes a few hours later (Cannot Ping or access the Host).  I thought it was my HW...but now am leaning towards the image.  The current host HW was running 7/24 for the past year.  I installed the image, booted the system, and updated it via the myServer interface.
Did I miss a configuration step?
FYI - doing this for my Disaster Recovery plan so I can recreate the system quickly if it's required.  In a "Smart Home" the control systems have become super important to the operation of the home (meaning, if they crash, the family screams!!!)
Re: Master Image Issue? (Crashing)
#3086
Not aware of any issue like that with the Master Image.
#3087
Please clarify what you mean by updated.  If this is effectively a fresh install on new hardware, did you activate your license and download and configure all the drivers?  I assume so, but it's worth asking.
Or do you just mean updating the OS, and you are not getting to the MyServer part, because it's crashing?
One of the reasons I chose to run myServer in a VM on my QNAP is that I can make regular backups of the entire VM.  This simplifies disaster recovery.
#3088
You can also clone your existing usb in the Pi it's already in.  The clone software is part of the Master Image.
If that clone'd USB is put into a second PI, then it will need a fresh license or it will go Expired.
#3089
I simply grabbed the Master image off the Allonis Website and flashed a SSD with the image. The PI booted fine, and runs for 4-8hrs before it is dead...
Updated means using the myServer webpage to update the software.
No license was used, just the trial. It's good for 30 days.
#3090
I hadn't really contemplated this strategy, but the more I think about it the more I'm liking the idea of running this in a VM on my NAS. I've been contemplating buying/building another server as a backup but I think I might go down this path instead. Thanks!
