Core won't update this morning...
gancier57's Avatar Topic Author
My Core MyServer6 app is reporting that it needs to be updated.  When I go to install, the file won't fully download...and tried again and again.  No luck.  Have I somehow corrupted the Core file?  Also, I seem to be caught in a doom loop with Sonos driver...keeps reporting errors over and over and over.  How do I delete that driver?  I suspect these issues are related.
Garth
Re: Core won't update this morning...
Tried to connect via Teamviewer and the system isn't allowing that.  So something is different from how it shipped to you.
You can try rebooting it gracefully.  Do NOT power cycle it (ever - if possible).
My guess is it was in the middle of an OS update and got power cycled which shortcut the scripted process so now it's not happy.
Put a monitor keyboard / mouse on it and see what it is doing.  Click on TeamViewer icon on bottom right tray to see if that is running.  If the TeamViewer license is needing attention, grant approval.
Try doing an update via the updater icon on bottom right next to Teamviewer (it will display if there are updates).  allonis is the password that might prompt up.
To delete a driver / app, bring that up in the Drivers  / Applications window and click the X on the bottom right and restart myServer.
If you need more help let us know.
Worse case you might need to reimage the NVME drive (internal).
Yes, it's been power cycling on and off...now mostly frozen, and won't turn off in from software dashboard. I did turn on Teamviewer to allow incoming connections...it was off.
Sounds like like I need the SD card you recommend, and download a fresh copy.
I think I can handle that.
#688
Not SD card...M.2 NVME to USB adapter is needed
www.amazon.com/gp/product/B08FWZXT2N/ref..._title?ie=UTF8&psc=1
OK, just bought that on Amazon, downloaded MyServer 6 file, installed Etcher and Docker. I was thinking I could just make a USB 3.0 stick into a boot drive...but I'll wait for this new one from Amazon.
#875
Well David, the good news is that I downloaded the Allonis Master file onto a USB/SSD card...and rebooted the MyServer on the Pi...
Problem is - since I'm not very good at this - all of my account settings are gone. Did the updates, but no settings. My TeamViewer is showing an ID of 1 660 106 269. I think I need a pro to work with me for a bit to truly get this back up and running. Thoughts?
Garth Ancier
(310) 890-8445
