Need help with IR
Need help with IR
2 years 5 months ago
#2239
I am trying to set up IR control. Ultimately I'm trying to do this because I can't seem to get Samsung smartTV driver to work with my TV, so I am hoping to use IR instead.
In have the Generic IR driver installed, and I have my smart remote configured in the driver. I have Samsung IR codes added to my IR database, but when I turn on the remote I am not seeing anything to suggest I can send the IR commands from it.
I have read the instructions, but am very lost here:3) In your SmartRemote UI folder, assign hard buttons commands like:Control|{{{{activeroom_{{clientname}}}}_smartremote_id}}~SendIR~SamsungTV~POWER Toggle4) Add your SmartRemote to your activate-room.roomname macro:SetVariable|{{activeroom_{{clientname}}}}_smartremote_id~61!"61" is the SmartRemote's ID in the GenericIR driver - this is to tell myServer that you will be using your SmartRemote to control your IR devices in the "Study" room.5) When pressed, that SmartRemote hardware is telling myServer to send an IR command to your IR device you called "SamsungTV" in the IR Database.  And to issue the POWER Toggle IR command.
What is the SmartRemote UI folder? What do I need to do now so that I can make the IR commands from the remote?
PhoenixF15E's Avatar
Re: Need help with IR
#2240
The SmartRemote UI folder is in MyDesigner.  You will have to remove "sample" from the initial SmartRemote template.  In the SmartRemote template there are multiple pages (tv,html, bluray.html, etc.) where you can add command codes to the hard keys.
Here are some tutorials to get you started.
Hope this helps!
