HomeAssistant -> Lutron Light not showing in SmartRemote but is in myDesigner
2 years 5 months ago
#2282
I connected HomeAssitant to myServer. I have a lutron light connected to home assistant which I see in myServer. This device is enabled. I have this device added as a source on myServer configuration page. When I open myDesigner's index.html file, I see the Lighting source that I added in myServer. However, I do not see this in SmartRemote.
Am I doing something wrong? why do I see it in myDesigner and myServer but not smart remote?
Also, unrelated but I tried to add images to this post but am not able to. The Add Files button doesn't work for me (using Chrome) and neither does drag/drop.
PhoenixF15E's Avatar
Re: HomeAssistant -> Lutron Light not showing in SmartRemote but is in myDesigner
#2284
I'll let the experts help with your Lutron issue.  One thing you might check is to see if you have a smartremote-sample and a smartremote page in MyDesigner.  If you do, you might have multiple index.html files.  To fix this you move the existing smartremote folder to an archive and remove "-sample" from the new file.  You will then need to update the project in MyDesigner.
Another thing to try is to hit the "Update Project" button in MyDesigner and restart your SmartRemote to make sure everything is in sync.
For some reason you can't post files on the first post in a new subject.  You can in the subsequent messages.
Last edit: 2 years 5 months ago by PhoenixF15E.
