Xfinity onscreen keypad
matt@weinbaum.com's Avatar Topic Author
2 years 4 months ago
#2649
I'm trying to get the cabletv.html onscreen keypad to work like the xfinity remotes. Usually when you press each key on an xfinity remote it starts entering it on the tv then you just hit the center button on the remote to change channels.
On the SmartRemote you have to type all the digits, then hit enter for it to transmit to the cablebox, then hit OK on the physical button for the channel to change.
Re: Xfinity onscreen keypad
#2653
That can be changed. The idea was to allow the end user's to be able to edit a mistyped channel before sending that to the cable box. So Bar patrons don't get a wrong channel to view while the Bar Tender fixes the typo...this can be changed easy enough. We will add this to a near future template.
Matt22's Avatar
2 years 3 months ago
#2702
As a work around how do I make the "enter" softkey also enter the "OK" function behind the scenes each time it's pressed?
#2703
If you want to have direct number import edit the CableTV page in the designer and change the commands under the numeric keypad to the following
0 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 0
1 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 1
2 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 2
3 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 3
4 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 4
5 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 5
6 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 6
7 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 7
8 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 8
9 = AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 9
Enter = AV|{{active_cabletv_{{clientname}}}}~Remote~Cursor Enter
if you want to see the numbers that you press echoed on the remotes screen then the button commands turn into macros like this
0 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}0!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 0
1 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}1!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 1
2 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}2!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 2
3 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}3!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 3
4 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}4!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 4
5 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}5!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 5
6 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}6!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 6
7 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}7!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 7
8 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}8!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 8
9 = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~{{av_{{active_cabletv_{{clientname}}}}_buffer}}9!AV|{{active_cabletv_{{clientname}}}}~Remote~Digit 9
Enter = Macro|SetVariable|av_{{active_cabletv_{{clientname}}}}_buffer~!AV|{{active_cabletv_{{clientname}}}}~Remote~Cursor Enter
Last edit: 2 years 3 months ago by davep.
Time to create page: 0.394 seconds
