Delay after Waking up
2 years 1 month ago
#3188
Just wondering out loud... Is there a way to send a dummy command to the server when the remote comes out of sleep?  There is typically a delay where the first command doesn't work.  The second time hitting the button works fine.
Not a big deal, but it would be a nice have if it was possible (and it solved the problem)
Re: Delay after Waking up
2 years 1 month ago
#3189
I have noticed this as well. I suspect that the initial command is lost due to the remote being asleep. After the remote wakes up, it can then respond to the next command.
I can eliminate that missed command by ensuring the screen is on before initiating the command (my remote is configured to turn on when it detects movement).
2 years 1 month ago
#3190
It's a bit weird, after waking up it's hit or miss if the first command goes through. There really isn't any pattern if it works or not. It's not a big deal, just a minor annoyance.
2 years 1 month ago
#3199
Often, the first touch is to put focus on the screen. The second touch is then understood as the command to process.
2 years 1 month ago
#3200
That is why I was wondering if you could have the remove do the "first" touch automatically so the second one would fire. Basically send a keystroke that does nothing...
randyf's Avatar
2 years 1 month ago
#3204
For me, if we're watching something, the first touch is usually hitting the pause button or adjusting the volume, so a hard-button press is being used.  If there is some way to allow configurability to the wake-up function, that would be nice.
