Remote Stuck
Matt22's Avatar Topic Author
Remote Stuck
1 year 7 months ago
#4045
My remote is stuck with the spinning circle. I've tried reboot multiple times and also rebooted myserver same results. What are my options?
Re: Remote Stuck
1 year 7 months ago
#4048
Whats the history...have you been using the SmartRemote already? Was it configured to connect to myServer to the proper folder? Did you do a ForcedUninstall to upgrade the smartremote.apk?
Help us with some context.
Re: Remote Stuck
1 year 7 months ago
#4049
Yes it was fully functional and connecting to myserver before hand. With no upgrades or changes for at least 3-4 months. The remote wasn't making great contact with the charging base and we didn't notice for a few weeks. So battery was dead. After re-charge it shows the animation and just the spinning circle.
Re: Remote Stuck
1 year 7 months ago
#4050
Push and hold the Power button to attempt to do a Power Down. Hopefully that will work. If not, send the remote back and we'll try to restore the firmware.
I suspect the power cycle got unlucky and corrupted a bit in the memory.
Computing devices should never be allowed to do ungraceful power cycles.
FYI, I posted an Automation Rule that alerts any / all web clients that a particular SmartRemote is needing to be charged. There is a variable that tracks current battery %. Use that as the Trigger. Then, the Action of your choice for alert.
Time to create page: 0.376 seconds
