Apps displayed but non-clickable
abigmoocow's Avatar Topic Author
I am in the process of setting up the SmartRemote.  I am able to get the remote to connect to myServer, see my users, rooms, sources, and apps; but when I click on an app nothing happens.  No error, no message, it just does nothing.
Is there an additional step to configuring the apps after defining them and placing them in the correct room(s)?
Thanks!
Re: Apps displayed but non-clickable
Thanks!
The easy answer is please follow the documentation step for step.  If you did something out of order, or not exactly how it's supposed to be done, then this will happen.
Send me an email with your Teamviewer ID and I can take a look.
#395
Steps completed today:
1) Updated OS
2) Updated myServer software to 6.7.3210.42954
3) Defined Users
4) Defined Rooms
5) Defined Sources
6) Installed additional software for my devices
7) Configured drivers
8) Configured Applets
9) configured Sources & Apps By Rooms
10) Setup myDesigner6
11) Renamed smartremote-sample to smartremote
12) Connected smartremote
13) See icons, when I touch them nothing happens
14) Looking at the Live Event Log, I don't see any errors or actions happen when I try selecting any app
15) Verified my license shows permanent instead of trial
16) Using Raspberry Pi official power supply
17) Pi temperature is < 70C
I'm using Sonos, Weather, and Heos Applets as my test subjects since those seem like the most basic to setup / prevent screwing up.
Just a few pointers on what to check would be helpful, will help me learn.
Last edit: 2 years 8 months ago by abigmoocow.
1) Updated OS
3) Defined Users
4) Defined Rooms
5) Defined Sources
I didn't see your myServer online.  did you figure out the problem?
The temp typically should be less than 50C.  70 is too high.  Does it have a heat sink and fan now?
What icons are not doing anything when you click them?
The Pi has always had heatsinks on all 3 compute chips, including yesterday.
Attached is a screenshot from my webbrowser for demonstration, but it's basically what the remote is showing (remote displays properly the battery, etc).
Selecting any of the four icons (AVR, Heos, Sonos, Weather) does nothing.
#402
Ok, good.  What is the temp of the CPU that is displayed in the myServer Dashboard?  Should be 50C or lower.  70C is way too high and is where the RaspberryOS / firmware starts to drop CPU performance to self protect.  You typically need heat sinks AND a fan to keep temps down.   Also, are you still seeing the "Low Power" message on the top right of the Raspberry OS dashboard?  If so, then there is a power supply problem still.  These aren't a myServer / Allonis issue, it's standard Raspberry Pi requirements.
Your system still shows as offline so we can't assist any further.  Send us an email if you need additional assistance with both your TeamViewer myServer ID and your TV ID / password for the myDesigner Windows PC.
Thanx!!!
