Restore myServer or have delete permissions on folders
I have download a folder for a project to setup a JVC projector and the data got disbursed incorrectly and I don’t have permissions to delete top level folders under wwwroot.
If having those permissions is correct then I need to have myServer6 restored to before the download or some other option to get rid of the data.
Thank you,
Tom
Re: Restore myServer or have delete permissions on folders
Thank you,
Tom
For the benefit of others, I wouldn't copy another users entire project file to your myServer.  Just copy the .html file(s) and the images folder (for unique / new images not in your system).  And ensure you put the images in the right image folder (there is an image folder at same level as the project folders, and then there are project specific images within the project folder.
Ensure you are using the latest myDesigner and then Update the project by clicking on the project name and then the Update button (top task bar).  Wait few seconds.  Clear the cache on your user interface device (or restart smartremote.apk).
It looks like I'm still having residual affects from the initial issue above on myDesigner.  When I try to open an .html file the file flashes and then disappears. With the file still open I see 4 dots to the top right of the screen going up and down, i'm assuming it is trying to open the file but not sure.  The events listing doesn't show any errors.  I did all the tips and tricks mentioned.  Connection to the myServer is working.
I reloaded myDesigner 2 more times and have the same results.  Not sure where to go from here.
Thank you,
Tom
Bumping this to be sure I'm still on the list.
Thank you,
Tom
#663
Thank you,
Tom
Hi Tom,
myDesigner had //http:// in its settings - that is an invalid url.
Fixed.  http:// - that is correct
David
Looks like It's break time with that move!
Thank you,
Tom
