Smartremote screen "empty" but kind of works on browser
RoyN's Avatar Topic Author
Re: Smartremote screen "empty" but kind of works on browser
Did you happen to remote in and check? If so did you rename it?   I'm still getting the same behavior... I see the sample folder and the "non sample" one, through myDesigner so I guess you fixed that.  Nonetheless, the remote still shows "Living Room" and a blank blue screen under.... Through the browser I see the icons for all the sources (even those that I dont have and that popped up at the last update), but clicking them doesnt do anything.  Also, if I try to change rooms from the browser I get the "No Data" message like on the remote despite having 2 created rooms (and some that were already there).
Also in the AndroidTV driver power test screen the smart remote is showing a red X...not sure if this has any debug value...
As an update, I've noticed that the battery indicator on the smartremote hasnt changed at all recently (despite being on the charger for the past 2-3hs...).
I'm getting very weird behavior... I removed and re-added the rooms, removed the sources that I dont have, re-added only a source for AndroidTV and one for Sonos, now I'm getting the "No data" in the browser room selector, and on the smartremote its showing the new rooms I added in place of the ones I deleted... It seems something is definitely amiss...
I dont have a lot of time to tinker right now, can I use your professional services to get this setup?  I see an hourly rate listed on the shop but it seems geared towards Bars?  Would you be able to get me running with the following setup?
2 Room (Master Bedroom & Living Room).
Each room has the same hardware:
- Cable box (IR)
- Tizen Samsung TV
- Android settop box
- Sonos sound bar (Beam & Arc).
Can you give me an idea of how many hours it would require?  I have the wife pressuring me, so I wont have time to learn this as I was planning...
#659
No dice... the network is connected correctly, and I was able to reach it via ADB and check the myServer IP is correct and so is the template name...
Edit: the sources highlighted in red just appeared after the last update...
Roy, in the webpage view of the smartremote project, you haven't selected a room and the icons for Unknown room are displayed
In the Smartremote, you have which filtered all icons out because your devices are not associated to a room.
Yes, we can help you get this all working.  I will need to log into the system to see where things are at.
Time to create page: 0.467 seconds
