New Driver - reduced commands?
Re: New Driver - reduced commands?
#1970
None of them worked... They are being sent from the server using the Command Builder so I know they are formatted correctly.
There is a bug in the command builder for the Sony TV driver.
When you select Remote, the command looks like this:  AV|<device id>~Remote~Command
Fill in the target device, and it looks like this:  AV|1~Remote
Choose a remote command, and it looks like this:  AV|1~RemoteReturn
The correct command is:  AV|1~Remote~Return
You need to manually add the ~ until they fix the bug in the driver.
#1971
Fixed in today's driver update.
bitzerjd's Avatar
#1975
What I found is that "Return" doesn't work as a "Select", it appears to be a "go back" command. "Confirm" was the command I needed. It works now!
Time to create page: 0.368 seconds
