New Driver - reduced commands?
2 years 9 months ago
#772
I was doing some testing of the Sony TV driver yesterday. I could turn on the TV and move around. The Enter key didn't seem to work.
I noticed there was a new Sony TV driver last night (and a new myServer) - updated both.
This morning I went to the new Sony TV driver to see of the Enter key was correct. There appears to be far fewer commands available when I select Driver Command Testing.
Re: New Driver - reduced commands?
#798
I'm making an attempt to normalize all the drivers into a unified set of commands. The missing commands are now under the Remote category.
So the old AV|12~Play is now under AV|12~Remote~Play.
They are all still there. Command build will list them.
Driver Command Testing is not building the commands correctly.
I am trying to select the TV as an input.
The command is being created as:  AV|1~RemoteTV, when it needs to be:  AV|1~Remote~TV.
bitzerjd's Avatar
#1962
I have a Sony A95L TV and cannot find a command that works for "Enter" or "Select".  I can bring up the Options menu, but cannot make any choices.  The driver installed is the latest. This key is pretty critical.
#1963
I assume you have tried the default:
AV|{{active_tv_{{clientname}}}}~Remote~Enter
How about Return, or DPadCenter?
If you are using Driver Command Testing, don't forget to manually insert the missing ~ between the word Remote and the Command.
bitzerjd's Avatar
#1964
None of them worked... They are being sent from the server using the Command Builder so I know they are formatted correctly.
Time to create page: 0.092 seconds
