Harmony. Hub
frlejo's Avatar Topic Author
Harmony. Hub
#1119
My harmony hub works very slow, or not at all since the last few updates. I have rebooted my router, my hub, myserver6. I have updated the server and the hub with latest updates. It has been working good since I st the pi4 up. Any thoughts?
Re: Harmony. Hub
#1121
Is the Harmony driver logging anything that shows it having trouble communicating with the Hub?  Turn on verbose logging.
JGrana01's Avatar
Re: Harmony. Hub
#1146
Yes, I have experienced some odd issues with my Hub.
Davep - it might be related to the "ping" you are doing every 30 seconds or so.
The good news is that my Activities via the SmartRemote started and stopped fine.
Last night, I went to turn on my system but noticed the SmartRemote was dead - I left it off the charger all day.
Grabbed my Harmony Elite remote and selected my Activity (in this case - Watch AppleTV). At first, nothing happened - nothing went on. And, the Elite screen went to the initial screen of "Watch AppleTV" but was blank. Normally it populates with commands.
Tried the Elite back button, etc - nothing was happening. Then the TV and AVR came to life - but no display on the TV. I selected Off with the Elite - nothing.
Went over to the Allonis dashboard and did a Server shutdown. I was suspecting some kind of interaction.
The Hub and remote finally settled down and shut everything off.
Did the Watch AppleTV activity again - worked fine and quickly.
Maybe the strategy of the myServer frequent ping is too aggressive - at least while still having to use a Harmony Remote.
Maybe only ping before a myServer command to the hub?
Re: Harmony. Hub
#1148
That sounds similar to how our Harmony system started to behave in the last six months or so and what got me looking at SmartRemote in the first place. Starting and stopping activities seems to be the danger point and (possibly) when it goes wrong trying to talk to the Logitech servers. So I wouldn't be too quick to blame myServer unless you can repeat it.
JGrana01's Avatar
Re: Harmony. Hub
#1156
My system has been running fine. Maybe you have a network problem?
Sat32's Avatar
Re: Harmony. Hub
#1157
I'm still using my harmony while I get the smart remote going and it's more flaky then normal in the last two weeks I've had to reboot the thing twice and I've had this elite model for years and never had to do this before. Not sure if it's all the connections to the hub myserver, homeassistant thats causing the issues. But the harmony companion I have in my bedroom has the same connections and has been fine with no problems.
