command and or
Sat32's Avatar Topic Author
Re: command and or
#1500
Yeah this thing has so much potential, the biggest issue is fighting understanding.
I Keep testing stuff out and altering design plans over and over
As long as the harmony keeps working for the wife I can take my time playing with ideas
CrabbyPatties's Avatar
Re: command and or
#1501
Amen to that.
Re: command and or
#1537
this maybe a stupid question but how do you separate commands in a if?
if|isEQ{{varible}}##answer##av|23~command~1"???"av|2~command~2!##av|12~command~else!
Re: command and or
#1538
Not a stupid question, the If statements aren't the easiest to understand, especially if you're nesting them or trying to do multiple commands. I'll try and explain with an example written in C++ style and then the equivalent in MyServer6
if (count == 1)
a = 2;
b = 3;
else
c = 4;
Now in MyServer6 syntax as a single statement:
If|IsEqual##{{count}}##1##Macro|SetVariable|a~2!SetVariable|b~3##SetVariable|c~4
or how it looks inside a macro. Note the double !'s at the end of the if statement(this is where it can get tricky with the !'s):
Macro|
SetVariable|a~2!
SetVariable|b~3##SetVariable|c~4!
The issue with macros nested inside macros is keeping the !'s straight. The double ! at the end is to signify the end of one statement in the outer macro, whereas the single ! is to signify the end of a statement in the inner macro. As you can imagine if you start nesting more macros within each other you have to start adding in extra !'s to the outer macros, even comments.
For example:
Macro|
// Set the count !!
SetVariable|count~1!!
// Check the count !!
If|IsEqual##{{count}}##1##Macro|SetVariable|a~2!SetVariable|b~3##SetVariable|c~4!!
And then when you save the macro it would end up looking like the output below. I find the code above to be easier to read/write but after you save the macro you're stuck with this output:
Macro|
// Set the count !
SetVariable|a~2!
Hopefully that helps.
Re: command and or
#1539
Thanks for the help I got it working, after I did I figured out it's just easier to debug if there separated
Re: command and or
#1553
For the inline myServer If statement there is an easy test for AND where you can append the variables in the test.
For instance
if ((variable_x = on) AND (variable_y = off)) then
     do something interesting
The myServer version can be
If|isEQ##{{variable_x}}{{variable_y}}##onoff##do something interesting
The following user(s) said Thank You: bowlingbeeg, andrew
Time to create page: 0.314 seconds
