command and or
Sat32's Avatar Topic Author
command and or
#1489
Does any one know is there a way to use AND: OR: in macro's and how it would be written
"if|IsNE##{{av_47_power}}##1## AND: if|IsNE##{{av_49_power}}##on## DO|command##elseDo|command"
Also what happened to the WaitUntill command in the command builder still listed as No Such Command "Not Available"
is that going to be added or fixed?
Re: command and or
#1492
You could replicate simple ANDs and ORs by nesting IFs although it will get complicated quickly. For instance:
if A and B then
do this
could be written:
if A then     if B then         do this
And:
if A or B then
do that
could be written:
if A then     do that if B then     do that
You just need to translate that into myServer syntax.
Re: command and or
#1496
Yeah thats the hard part the header on the nested command syntax says Beta
so I'm not sure it's even impimented and there's no working examples in the documentaion.
here is what i was testing.
macro|
// test!
IF (livingroom_avamp_id = 50) THEN
    Lighting|8~Off;
ENDIF
Not sure if variables need to be wrapped in {{brackets}} or not
Tried both neither worked.
Re: command and or
#1497
The one line syntax should work (although it's very confusing). From the docs, if a=3 then do this else do that is written:
if|isequal##a##3##do this##do that
and then you can substitute another if/then instead of 'do this' or 'do that', but you have to use different delimiters to enable it to parse so it looks something like:
if|isequal##a##3##if|isequal&&b&&4&&do one&&do two##do that
Re: command and or
#1498
that was it never even looked at delimiters.
Now what about WaitUntill command?
I think a lot could be done with it.
Re: command and or
#1499
My 'just' in 'You just need to translate that into myServer syntax' was doing a bit of heavy lifting...
Time to create page: 0.363 seconds
