Bueller, Bueller, Bueller
Re: Bueller, Bueller, Bueller
Setting Up Remote ran into first brick wall
I have MyServer6 up and running on Pi4 and added users and rooms and a few devices
installed MyDesigner6 but it will not find any project templates
Settings:
file share: "\\MYSERVER-IP\myServer"
web server URL: "http://MYSERVER-IP/"
I'm also tried running MyDesigner as admin
and also disabling firewall "eset"
It seems there are several of us running into this specific issue so I hope it gets addressed sooner rather than later. I've been playing around with the server but I can't even begin to start setting up my remotes until this is resolved.
Settings:
Can we TeamViewer into the system to see how things are setup?
David if it helps you are welcome to remote into my server, and you are welcome to make any changes you feel necessary in order to get to the bottom of this.
Hi Nillaz,
Your system is not accessible to the Internet right now.  That starts to point to a networking issue which just may be the source of the problem.
Can you access the Internet from a browser from the myServer controller?
Hi Nillaz,
Hey David I just hooked up a monitor and kb/m to the server and I can bring up web pages in Chromium. I also tried to login to teamviewer from outside my network and can see the inbound connection on the server but I don't know what you guys set the password to so I can't complete the authentication. Do you want to try again?
Sat32's Avatar Topic Author
Hi David I posted this issue last night before going to bed assumed I made some config issue. I can access the internet from Pi Desktop. What do you need to teamview into server?
When I try to access MyServer6 from windows desktop I get this:
but from the pi desktop using loopback address it work fine. Will try rebooting server my router locked up sometime last night.
And BTW the myserver dashboard doesn't render correctly on mozzilla firefox, bottom of page is cut off unless switched to full screen.
