License Activation - Registered To name
Philnye's Avatar
Re: License Activation - Registered To name
I just tried the latest myServer build "6.7.3215.745" and the Owner on the License page still shows David Li. I repopulated everything except leaving the 3 optional username/passwords fields blank on the Owner Information page again just in case and unfortunately, still not updated. I'll keep watching for myServer updates and keep trying. I did resend the activation request after the latest update if you see a request from my server.
Thanks,
Phil Kosarek
philnye0@gmail.com
randyf's Avatar Topic Author
I also just updated to the latest myServer release and nothing changed.  Not sure if the update contained any fixes for that.
I also haven't seen any updates on the page in regards to the license activation.  Not sure if that has been completed or not.  I'm guessing I should see a value like Active or something in the License Status field.
Philnye's Avatar
Hey Randy, it does show License Active on the main dashboard home screen with Never expire. I just, like you, don't see any feedback on the license status on the actual license page itself.
Thanks,
Phil
Good point Phil, thanks for pointing that out.  I did see that but have been focused on the licensing page.  Time to move on to some other things, I'm sure this will get resolved soon.
the only things you all need to do re: license is fill out Owner's info, change the myServer computer name to something unique and send in an activation request
All is working fine with licensing.  Even if it shows you "David Li' on the registration page.  don't worry about that...that's a remnant of Allonis pre activating the Shelf systems.
The following user(s) said Thank You: Philnye
