AndroidTV driver bug maybe?
I updated my drivers to the latest this morning and my Nvidia Shield integration is hosed. I have changed nothing in regards to settings etc since the update but I did try rebooting the server and the Shield TV to see if it would resolve itself. The system will successfully send power commands over IP to trigger it on/off from both the remote and myServer6 but any other button press (i.e. dpad, enter, etc.) results in the debug log throwing an "ERROR · AndroidTV.RemoteCommand - No functional connected device named Shield TV"
Anyone else come across this yet? I'm wondering what the best path forward is. Should I nuke the Nvidia Shield in myServer6 and reinstall fresh?
Re: AndroidTV driver bug maybe?
Actually, while I'm at it trying to figure out what's up I've also discovered that you can no longer enable/disable devices from the driver page, nor can you enable/disable sources from the Sources and Apps page. You can still enable/disable items in the Sources and Apps by Room page.
Sat32's Avatar
don't have much configured on my remote but
opening the nvidia shield scene all the apps showed
and there was a back,home,hamburger icons on the bottom of screen don't remember
being there before. And the home button didn't work so i couldn't leave the scene and had to reboot remote to get back to index.
Sources and app's
now create non-av source app??
when did that change? but all the apps in dropdown still there kodi, jellyfin ect
thanks
Decided to try nuking the Shield from the AndroidTV driver and redo the Shield TV integration from scratch. The driver found the Shield as it always does but the result is the same except it will now not respond to a power on command as well. Power off still works. Otherwise the issue remains, with the system still throwing the error upon a keypress.
Sources and app's
thanks
I downloaded the latest myDesigner and see the shieldtv page you're talking about in the sample. I also see the button you're talking about in the Sources and Apps page.
Are your buttons functional? Can you control the Shield? If you press on an app icon on the screen does the Shield respond? I would switch to the new smartremote template in mydesigner and rebuild my scenes to see if that resolves it but I suspect that won't fix anything for me since I can't send commands from myServer itself.
Switched to the new template and no change. Nuked the AndroidTV driver and reinstalled and no change.
Dave, could you take a look a this?
