#758
I think I got the new Anthem driver setup, and it mostly works with my MRX1120.  I did run into a couple snags:
Unfortunately for me Discover didn't work, but I was able to add it manually.
While adding my Anthem, it didn't entirely work.  I ran the following command: Anthem|AddAmp~MRX1120~192.168.0.98~Home Theater, however it added the IP address as the Model, and the IP address was blank.  I filled out the IP address correctly and myServer was able to connect and control it.
Mute, source selections, power off, and power on work, but volume up/down and power toggle (don't care about the last one personally).
I was seeing the following errors in the log, but they seem to have cleared up after turning the Anthem off and on.
13/02/2024 21:19:39.19 · DEBUG · Server.doCommand - AV|{{active_anthem_{{clientname}}}}~Source~2 from dashboard-fx-posm 13/02/2024 21:19:39.19 · DEBUG · Server.doCommand - AV|10~Source~2 13/02/2024 21:19:39.19 · ERROR · Anthem.ProcessResponse - Error in ProcessResponse - Index and length must refer to a location within the string. (Parameter 'length')
Great work so far!
Last edit: 2 years 7 months ago by stanger89.
Re: Anthem Driver
#760
I will want to remote into your system to see why it was not discovered. I suspect the zeroconf query failed.
Re: Anthem Driver
#768
Yeah, that's fine, do you have my Teamviewer ID, or do I need to get it to you?  And if so, how?
Re: Anthem Driver
#799
eMail me your teamviewer id. I'll be revisiting Anthem in the morning. There are slight protocol differences between models. Volume being one of them.
Re: Anthem Driver
#802
the info@ email?
Re: Anthem Driver
#938
The Anthem driver was updated on Friday. It should have resolved the discovery and volume issues previously reported.
