Re: Anthem Driver
#964
Volume works!  Thanks!
Re: Anthem Driver
#1354
I have maybe a weird question/request.  Is it possible to add support for the Paradigm PW Soundbar to the Anthem driver, or possibly a new driver?  By my research, the protocol is nearly identical to the Anthem protocol (which makes sense since they're the same parent company).  Here's the Paradigm IP protocol:
www.paradigm.com/index.php?controller=at...nt&id_attachment=222
I tried adding it by IP to the Anthem driver, but that as expected, didn't work.
bitzerjd's Avatar
Re: Anthem Driver
#1887
FYI - I did some testing today and the Volume (up/down) works, but changing it to a set value, or increasing/decreasing by a value (N), doesn't work.  No matter what the "N" was, it went up or down .5 per push.  My Anthem is a AVM70 8K.
Re: Anthem Driver
#1903
Is there a discrete volume control?  ie: set volume to X?
If so, try using a slider from the myDesigner webobjects.
bitzerjd's Avatar
Re: Anthem Driver
#1906
No idea...I'm just trying to use the drop down commands on the server and see how I can incorporate the commands into the Home Theater Logic. For example, watching Netflix movies usually have a setting of -23 (on the Pre/Prod). I would love to add this to a button instead of punching the Vol Up command.
bitzerjd's Avatar
Re: Anthem Driver
#1960
I tried the IRCmd commands and they are not working.  I tested Level, Lipsync, and a few others and they don't trigger anything on my AVR.  Is there a trick to get them working?  The normal ones (Volume up/down, Select Input) work fine.
Time to create page: 0.385 seconds
