I have a AVM60 and the driver is working for volume, mute, and source select.
However I would like to program in the buttons needed for OSD. Looking through the docs, I thought the test command would work with Zsimyyyy where yyyy is the simulated IR code. However it doesn't seem to work
Simulated IR Command values for ZxSIMyyyy (use 0 to fill in blanks Ex: Key 1 = 0001) yyyyMain Zone
IR Key0Key 01Key 12Key 23Key 34Key 45Key 56Key 67Key 78Key 89Key 910Power On11Power Off12Setup13Input14Mode15Dim16Level17Info18Up19Down20Left21Right22Select23Page Up24Page Down25Volume Up26Volume Down27Mute Toggle28Last29Tone30Bass31Treble32Lip Sync33Balance34Dynamics35Clear36Preset Simulated IR Command values yyyyZone 2 IR Key10Zone 2 On11Zone 2 Off13Zone 2 Input23Zone 2 Next Preset24Zone 2 Previous Preset25Zone 2 Volume Up26Zone 2 Volume Down27Zone 2 Mute Toggle
Last edit: 2 years 5 months ago by
Mark Guebert. Reason: Formatting
