App Launch
App Launch
2 years 4 months ago
#2876
I'm trying to launch Netflix via a button... using this command (from the command builder)
AV|{{active_atv}}~Launch~com.netflix.Netflix
When I execute it, nothing happens.  What am I missing?
Thanks!
Re: App Launch
#2878
Thanks!
Launch~com.netflix.Netflix is the proper launch command for this.
What happens if you change {{active_atv}} to the actual device id number? If you are using a server variable to indentify the proper ATV are you sure that {{active_atv}} is correct? I can't check right now but shouldn't it be something like {{active_appletv}}, or if invoking this from a remote shouldn't it be something like {{active_appletv_{{clientname}}}} ?
Re: App Launch
#2880
This is what is in the log...
11/07/2024 07:42:52.42 · DEBUG · Server.doCommand - AV|{{active_atv}}~Launch~com.netflix.Netflix from remote
11/07/2024 07:42:52.42 · DEBUG · Server.doCommand - AV|15~Launch~com.netflix.Netflix
11/07/2024 07:42:52.42 · DEBUG · AppleTV.doCommand - Cmd=[15~Launch~com.netflix.Netflix] Client=[remote]
11/07/2024 07:42:54.42 · DEBUG · AppleTV.RX: Family room -
15 is correct for the AppleTV device.
Re: App Launch
#2885
This looks correct so I'm not sure what is going on. I'll try to look at my log when I get home tonight.
Re: App Launch
#2887
My launch command works and this is what the log looks like.
It looks like you are missing line 4 though I have no idea how to resolve that. I assume the TX means this is the line sending the actual launch command to the Apple TV.
Server.doCommand - AV|{{active_appletv_{{clientname}}}}~Launch~com.netflix.Netflix from remote3
11/07/2024 20:47:10.47 · DEBUG · Server.doCommand - AV|7~Launch~com.netflix.Netflix
11/07/2024 20:47:10.47 · DEBUG · AppleTV.doCommand - Cmd=[7~Launch~com.netflix.Netflix] Client=[remote3]
11/07/2024 20:47:10.47 · DEBUG · AppleTV.TX: Apple TV - launch_app=com.netflix.Netflix
11/07/2024 20:47:13.47 · DEBUG · AppleTV.RX: Apple TV -
Last edit: 2 years 4 months ago by Nillaz. Reason: reformat line breaks for legibility
Re: App Launch
#2888
Thanks for checking!
Time to create page: 0.094 seconds
