IP and IR
IP and IR
8 months 3 days ago
#4830
I was bored and decided to play with IP control for my ATV again.  I setup a system variable (ATVcontrol) and set it to IR or IP.  Depending on the variable it loads a scene for either the IP or IR control.  I then modified it so the logic was in the button.  Each button calls a macro, the macro has an ISequal statement that does a simple If, Then, Else.  If ATVcontrol = IR run the IR command, if not IR, run the IP command.
I then added a button to the ATV scene that toggles the ATVcontrol variable and displays the current "control".   I like using IP control, but with the ATV I found previously that it would break when the ATV was updated.  With this setup, if that happens, I can simply press a button and switch it over to IR.
Is this needed...NOPE, it's just fun to play around with the system and have it do things like this.
Re: IP and IR
8 months 2 days ago
#4831
You don't have to make it that complicated. When I want to send an IR command to my Onkyo AV receiver, I do something like:
Control|4~SendIR~Oppo Digital-All Models (IR Address 1)~MAIN
The "Control|4" is my IR system emitter port.
When I want to send an IP command:
AV|4~Volume~Up
It is just coincidence that my emitter number (4) for IR commands is the same as the device number (4) for the IP commands.
So any of my control buttons on a scene can use either one.
I do this for Onkyo because the IP commands are only a subset of the available commands, so I supplement them with additional IR commands.
You probably notice I do not use Server variables to designate my devices. But the above can work the same with server variables if one chooses to.
Re: IP and IR
8 months 2 days ago
#4832
I'm not trying to mix commands within the scene. I'm switching the entire scene to IR or IP with the push of a button. I've had IP fail after an update, and in a pinch I can simply press a button and switch it over to IR.
I use system variables for all devices so if I muck with something (like switching my Global Cache devices I can simply update the one variable.
The nice thing about myServer is that there are many different ways to get things done.
Time to create page: 0.070 seconds
