Pairing Remote to AppleTV?
I have my appletv connected to HomeAssistant and so I pulled in that driver and it is much snappier. I'm still struggling with the macros and having all of the right server variables set correctly when using the HA driver but I can code around that for now.
#560
No can do with infrared as my ATV is in a server rack in a different room. No LOS is possible.
No Harmony Hub or GlobalCache IP2IR available?
HomeAssistant integration should also be possible.
I have both a Harmony Hub and an IP2IR. The IP2IR is needed for other devices that have no IP control capability and the Harmony integration doesn't work correctly in my system. It has the opposite problem of the ATV driver in that it appears to fire commands far to quickly. I mentioned this a few days ago when you were soliciting feedback and DaveP said there would be a Harmony driver update later that day that would address this. So far that update hasn't materialized. Frankly, if this one thing got addressed I could let all the other bugs/glitches I've encountered go until the overall system was more stable and mature. I could experiment at my leisure and at least I would have a functional remote in the meantime, even if the overall configuration was less than the ideal.
Home Assistant may be a possibility but I'd really rather not have another system in the mix. It's yet another thing I need to maintain and everything is complicated enough as it is.
CodZero's Avatar
Is it possible to use the Bluetooth in the harmony hub to drive the ATV commands ?
I'm going to piggyback off of my harmony for the first while until more drivers get built and released.
This is precisely what I intend to do for all of my devices which are currently running and controlled via the Harmony Hub / Elite remote (assuming the Logitech driver works properly). It makes more sense, I think, to use what definitely works and then I can test out with IP control of devices one at a time, and then work up to multi-device macros and transfer everything across from Harmony to Allonis.
While the system seems quite powerful - although I'll have to wait until I actually get mine, given it's been sitting in the delivery depot for three days now, waiting on the authorities sending me the customs charges to pay - it, like all new products, definitely appears to have some glitches to be ironed out (although a number of them do appear to be caused by users not reading the manual, so to speak).
I think, as well, as I've said elsewhere, there's been a combination of the product maybe being sent out before the documentation was ready, and this being a product aimed at consumer tech enthusiasts who will, regardless of how much you tell them, not stop tinkering and / or doing things out of order, like a bunch of unruly kids, unlike corporate concerns where the stuff is installed and managed remotely. Geeks like those of us who buy into systems like this are never gonna be content to sit back and let support do the work. I do recall David mentioning his surprise at the lack of take up in the KS for support, but i think this is the reason for that - we like to do things ourselves! David may be waking up shivering these days with nightmares of running round 90 different installs shouting "follow the instructions, read the manual, do it this way!", but honestly, with a product like this aimed at a consumer base like this that shouldn't really be a surprise - I bet 90% of the people who backed the SmartRemote also already run Home Assistant or something similar and are used to digging in.
I'm looking forward to three or six months down the line when the metaphorical dust has settled, the processes and procedures are all up to date, there are step by step walkthroughs for every install type, and all drivers work. I think this is gonna be a great system, and I'm willing to put up with a few stutters to get there - as long as the harmony and Home Assistant integrations work when I get my remote and server out of the box anyway.
We are testing a significant update to Harmony Hub integration today.  Keep posted.
stocks109's Avatar Topic Author
#909
I can confirm that the response time is extremely slow that it's basically unusable.
Time to create page: 0.297 seconds
