Pairing Remote to AppleTV?
stocks109's Avatar Topic Author
2 years 9 months ago
#525
Hi, with the help of David my AppleTV is now showing up in the designated room.
However, it's unclear how I pair the remote to ATV?  The instructions say open a terminal but do I do this on the server?  Is there a way I can issue that command via the MyServer dashboard?
Also, I have tried issuing the command via a terminal on the server but the command wasn't recognized so I'm stuck, at the moment.
#526
"Please make sure you are performing these operations from the same PC that myServer is running on. Also have a TV connected to the AppleTV that will be paired and have the AppleTV sitting on the top menu screen."
put the myserver controller on an HDMI monitor with a keyboard / mouse and open a Terminal Session (bottom left icon from the RaspberryOS desktop)
#529
I can confirm it does work. But I will say the appleTV driver is extremely slow for me. It takes 2-3 seconds per click for it to register. If you get it running let me know if it's slow for you as well.
#539
I assume you are talking about the process to register takes a few seconds (a one time process) and not the every click using the smartremote to control the AppleTV hardware (that should be near instant).
#541
No I mean every click of the directional arrow or selecting something.  It's painfully slow, but I was waiting for others to try it out to see if it was just me or if everyone had the same issue.  I figured I've reported enough issues so far :)
#542
that doesn't sound right...we use that driver is LOTS of commercial installs and have not had any negative response.  I don't have an AppleTV here to test.
Time to create page: 0.099 seconds
